why not just underclock the chip... IMO I would not cut any holes in the outer panels. sounds like trouble. and if I were buying a car and saw you cut a hole, I dont care what the reason I wouldnt pay 2cents for the car.
Id definitly investigate a better way than that. under the car could be extremely hot anyway, hotter than inside, black pavement and the heat of the transmission and motor all under there. naw, wouldnt do that at all.
Id try underclocking it. chances are you could run pretty safe at 600mhz or something, and that should keep the chip considerably cooler.
LinkBack URL
About LinkBacks
, make some venting going from a floor vent and run that to your PC. I did this and it works pretty good. all vents run under neath carpet so you dont even see them. I made the vents from old vaccuum cleaner attachments becaus they were flat and fit on to the vent in my car. Lucky. Water cooling is common, but kind of sucks on a cold day if your cooling your computer. Im in wisconsin and travel south occasionally so I needed it to run off the cars vents. Now that I placed the computer inside the cab of the car, I did away with the venting thing, but it does work good.
