Page 3 of 16 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 152
Thread: my ideas to combat heat
  1. #21
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    A TEC aka peltier (a thermo eletric cooler uses the peltier effect) is simply a heat pump, it sucks heat from one side of the tec to the other, dumping it what ever heatsink/intercooler one might have. It simply moves the heat from one point to another, adding its own thermal inefficiencies in the processes. The cyrix chip might be low wattage, but if the tec wasnt able to dump all the heat into the surrounding air, itd simply start cooking the chip.
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
  2. #22
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    ^^See, that works when the car is running, but i want to be able to leave the computer on all the time.
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    I'M DEBT FREE!!
    I'm now a reasonably successful gunblogger.
  3. #23
    Sep 2002
    Austin / Houston TX
    Water cooling works well because water has a high specific heat - so it keeps its temperature longer. This is why you can bite into the crust in your pizza w/ problems but not the toppings that have more water/oil.
    When you get back into your car after a hot afternoon, grab a hold of that water bottle sliding around in the back seat - it'll be quite hot. How long will it take to cool that down to the point where it benefits the cpu? Cooling that bottle down takes a lot longer than cooling the cabin down to a manageable temp. Granted you'll have a radiator for the water... but just a thought.
    They sell these solar-powered fans that clip onto your car windows. I've been toying around with the idea of getting a few solar panels, coupling them with a small tank battery, and a few low power case blowers. If it's your car, then i wouldn't worry about the hole,you can always patch it (providing it's done right). have an in and out port with butterfly valves. you can even set up a system that will open and close them using shifter hardware for a mountain bike. Just make the in/out tubes into an S to prevent any major splashes coming into your case. I'd also put a really fine mesh in the opening (and perhaps some filters - like a scouring pad or something). Of course this will reduce your airflow so you may need bigger openings.
    Also, someone correctme if I'm wrong, but doesn't condensation happen when hot moist air is rapidly cooled (touches something cold)? I've never had a problem with condensation in a Texas summer, unless the AC is turned on full blast and it's blowing directly at a window. During the winter you could just shut the valves. Besides, isn't winter air naturally dry? So you'd be concerned with the moisture that you're bringing in yourself - which is the same concern everyone else on this board has (nothing new by dding the vents).
    Just some thoughts. Best of luck!
    -F
    No Carputer YET.
    A car I'm designing...
  4. #24
    Feb 2004
    Elmira NY
    it get realy hot b/c the glass in the car. maybe your glove box isnt as hot since its closed off from the sun
  5. #25
    Constant Bitrate Magnezium's Avatar
    Oct 2003
    Los Angeles, CA
    I live in a hot area of Southern Cali. The best way to vent the computer (that I've seen) was to use a duct from the grill of the front of the car (obviously filtered) through the firewall and direct to the computer. Now I do believe that is REALLY exteme and not worth the time and effort. But, using something similar, you could properly vent the PC. If you have vents in your rocker-pannels, or if you put any face (ricer) air scoops on your car, I'm sure that would work.
    I recomend just putting over-kill heat sinks and fans on. I put a XP3300 Heatsink and fan on a 1.13 GHz PIII and it took the temp down to 25 degrees under idle and 34 degrees under 100% load. It was really stable and pretty damn quiet. I believe it was made by Techtools and only put a 15 dollar dent in my wallet after tax. Give it a try before you destroy something on your car.
    MG
    Just your friendly neighborhood computer specialist.
    2002 Pontiac Trans Am WS.6
    Silver/Black
    Looks like new... Wanna know why they call me "Crash"?
  6. #26
    Mar 2004
    CT
    As for overkill heatsinks, if your in a car that you tend to drive to it's limits...not that i do that ....
    you might want to take into account the weight of the heatsink. Some overkill sinks go well beyond spec in tems of weight and the stress placed on the motherboards may end up being enough to break the suckers loose and let them go to town in your case.
  7. #27
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by wizardPC
    So how is the hole in the bottom of your car going to help if the car is stationary?
    If it's heat when the engine is not on, you are going to have to have something that is powered and moving. More drain on bettery.
    Suggest you move to alaska.
  8. #28
    Jun 2000
    Nashville
    fans connected to my second battery.
    I'M DEBT FREE!!
  9. #29
    Jan 2002
    Chicagoland, IL
    Quote Originally Posted by Magnezium
    MG
    trunk scoop on a saturn thats just an amusing mental picture.
    -Nick
  10. #30
    Constant Bitrate Adam432823's Avatar
    Nov 2003
    S.F. Bay Area
    I don't leave my pc on all the time like Wizard says he does, but when I leave my car in the parking lot and then come back, the internal temperature is so high that it prevents the pc from passing post. Yet, once the fans begin to run, it cools off enough that all i have to do is reset the machine. That's a pain in the ***. Basically I need to move all the air out of the trunk while the car is parked. I was thinking something along the lines of a series of solar powered fans forcing air into the trunk from the outside. Not into the PC case itself, just the ambient air in the trunk.
    I'm hoping more people reply to this thread. No idea is too wierd!
  1. To heat sink or not to heat sink ...
    By jnusaira in forum Newbie
    Last Post: 02-18-2004, 09:46 AM
  2. CPU Heat question: Which one would generate less heat?
    By kiztope in forum General Hardware Discussion
    Last Post: 02-12-2004, 02:14 AM
  3. Summer heat MP3Car trial complete
    By Moose in forum General Hardware Discussion
    Last Post: 07-10-2003, 12:25 AM
  4. help with ideas for a total homebrew mp3 car player
    By acidic in forum General Hardware Discussion
    Last Post: 07-12-2002, 11:02 AM
  5. COOLING THE CARPUTER
    By moahdib in forum General Hardware Discussion
    Last Post: 07-04-2002, 08:18 AM
