Couple side notes on this whole subject. Keep in mind if you are having issues with your computer booting in your 100 degree trunk water cooling will only help if you have the hot side of the system in a place with temps below 100 degrees.
I have yet to test it but it seems to me the best solution would be to use the peltier cooling like they have in the little coolers. A few years back(like p1 days) they used to make peltier computer heat sinks so this idea cant be totally flawed. I got one of those little coolers over the summer for like 10$ and eventually just decided to tear it apart so i am looking at all the pieces right now. there are a couple advantages... 1, it runs on a 12 volt
power suppy so you can wire it straight into the car electrical system, pretty simple. 2 this would allow you to get temperatures that are actually get temperatures that are lower than the surrounding air.
I know a couple people mentioned that these things produce lots of condensation and i agree with them, they are right. But would it be the hardest thing in the world to position so that it just isnt over anything important? from my observations, water only ever falls down, so if you say mounted it on the side of your case over the mobo you shouldnt have any problems.
thats just my 2 cents
