Page 7 of 16 FirstFirst 12345678910111213141516 LastLast
Results 61 to 70 of 152
Thread: my ideas to combat heat
  1. #61
    Mar 2004
    CT
    that's not a half bad idea for when the car is moving... but the question is how it would work when the car is sationary... I'd think that the water would just end up getting hot and your back to the same problem.
  2. #62
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    But I have an Epia, dammit!
    If I could watercool it I would
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    I'M DEBT FREE!!
    I'm now a reasonably successful gunblogger.
  3. #63
    Sep 2002
    Austin / Houston TX
    Quote Originally Posted by Mr.Sinister
    AHEM!!
    ... and you guys thought I was nutz for suggesting water cooling.
    I present to you somebody who's done it:
    http://www.overclockers.com/tips1144/
    Oh I think water cooling is great. It's just that Wizard wanted something for when his car is standing still with the engine off. I mean, once the car gets going the cabin temp should reach an acceptable level for the cpu. I didn't think it was valid to try and water cool a cpu with 100°F+ water that has been sitting inside the car - especially since it also involved dumping heat from the radiator to the inside of the car. Once you get going water cooling using an external would be awesome (although a project in itself).
    I mean, I guess you could use this guy's setup and put a fan behind the radiator that runs off of solar power - but perhaps Wizard may want to try a less expensive (both time and $) solution first?
    Good find.
    [edit:]
    anaxagoras beat me to it...sorry for rehashing the same thing.
    No Carputer YET.
    A car I'm designing...
  4. #64
    Newbie Mr.Sinister's Avatar
    Jan 2004
    Massachusetts, USA
    Quote Originally Posted by Filip
    Good find.
    [edit:]
    True...
    "The rest of the details are pretty much like any other water cooled rig. Since I needed 120v AC for the Mini-PC, I used a 120v Eheim 1048 pump. For the ˝" water lines to and from the radiator, I actually used aluminum fuel lines. I could get away with just a loop of that line up to the front of the car and back and ditch the radiator, but it's nice to have, just-in-case." (my italics - Mr.S)
    If I read that right, the fuel line is acting like a heat sink (along with the areas it's contacting the body of the car), and just put the radiator there as a precaution. Essentially, the aluminum fuel line is acting like a radiator, along with the oil cooler that he put behind his fog light. If you think about it, the radiator, combined with the roughly 15 feet of aluminum fuel line, has one heckuvalot of surface area.
    Since I'm not the guy who did the install, I can't answer specific questions. Two questions I myself have about the install are:
    1) Where does this guy live? If he lives in the northern parts of the US or Europe, did he use anti-freeze in the coolant. If not, look out around December! The busted pipes should be a sight to behold. The catch-22 of it all though is that using anti-freeze is going to have an effect on how low the temps of the coolant will go to.
    2) How are the temps after the car's been sitting in the sun for a while. This is the same question that all of you have. While not too many people are probably going to use their system for very long while the car engine is off and the car is parked(most people won't use it for very long because they'll kill their battery. A buddy of mine can kill his battery in a hour with just his stereo being turned on. Of course it doesn't help that he has two high-powered amps, and a Boston Acoustics 10.5LF sub ), it's still an issue that has to be addressed.
    If *I* was building that setup, I wouldn't have used a 120V pump. But, then again, that's just me. He may have just had it lying around, and instead of buying a 12V pump, just used that one instead.
    Oh yeah, Wiz... I agree with you. You shouldn't have to go to extremes to cool an EPIA board. On the flip side, there should be a way to remove the glued on heatsink of the M10000 without killing the board. It's probably epoxied on, which means you'd have to stick it in the freezer (inside an ESD bag of course!) for a couple of hours to make the glue bittle. Definitely not for the faint of heart.
  5. #65
    Jan 2004
    Massachusetts, USA
    Oh yeah.. something else just came to mind.
    We're all going on the asumption that the machine is crashing because the CPU is overheating. Who's to say that it's not something else on the board that's causing the machine to crash? As dumb as this may seem, you may want to give your board a once-over, and see if there's any suspicious looking solder joints or discolored components on it.
    If you had access to one, it'd be a Godsend if you could use a thermal imager to see the hotspots on the board (i.e.: http://www.bigbruin.com/html/thermal_images.htm).
  6. #66
    Maximum Bitrate eCar™'s Avatar
    May 2003
    SE Michigan
    I am not assuming that the CPU is overheating.
    Quote Originally Posted by eCar™
    I would say that if you have to go to any kind of extreme measures to cool a C3, you have problems. Fix the problem and forget about the special cooling.
    Withstanding heat and low power consumption is the C3's claim to fame. The thing only produces like 10 watts of heat max. You've all seen the movie.
    It is more likely some other component that is having trouble with the heat. Try trading memory out. Or HD, etc.
  7. #67
    Jan 2004
    Massachusetts, USA
    OK, I stand corrected. I didn't see your original post there eCar.
    BTW, I never saw that video before either.
  8. #68
    Nov 2003
    how about an air to air intercooler? use a fan or fans in the case to circulate the air to the intercooler mounted in an area where there a lot of ventaltion? and use a solar panel (i've seen some little ones for $50) to circulate the air and blow on the intercooler to chill it, just a thought, as long a the case is sealed you should be fine
  9. #69
    Jun 2000
    Nashville
    okay, after talking about this with my father (who has worked in industrial HVAC for 35 years), this is the current plan.
    i'm gonna buy two of these:
    they are 3" vents for marine engine compartments.
    I gonna mount them facing rearward to prevent water from being forced into the trunk when i'm driving 80 on the interstate in the rain.
    now, if I can only find some fans that are designed for 3" ductwork
    I'M DEBT FREE!!
  10. #70
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    3" ~ 80mm
    -Nick
    _____________________________
    www.mp3vw.com
  1. To heat sink or not to heat sink ...
    By jnusaira in forum Newbie
    Last Post: 02-18-2004, 10:46 AM
  2. CPU Heat question: Which one would generate less heat?
    By kiztope in forum General Hardware Discussion
    Last Post: 02-12-2004, 03:14 AM
  3. Summer heat MP3Car trial complete
    By Moose in forum General Hardware Discussion
    Last Post: 07-10-2003, 01:25 AM
  4. help with ideas for a total homebrew mp3 car player
    By acidic in forum General Hardware Discussion
    Last Post: 07-12-2002, 12:02 PM
  5. COOLING THE CARPUTER
    By moahdib in forum General Hardware Discussion
    Last Post: 07-04-2002, 09:18 AM
