Page 8 of 16 FirstFirst 12345678910111213141516 LastLast
Results 71 to 80 of 152
Thread: my ideas to combat heat
  1. #71
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    oh, yeah, if I can't find any I fully intend to use 80mm fans instead.
    what I'm looking for is something like this:
    http://www.smarthome.com/3011.html
    only for 3" ductwork. The 4" one on that page wont fit underneath my false floor
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    I'M DEBT FREE!!
    I'm now a reasonably successful gunblogger.
  2. #72
    Constant Bitrate aleromaster's Avatar
    Nov 2003
    Valrico, FL
    2002 Oldsmobile Alero GL2 4DR
    Aleroputer 90% done (ripped out and being rewired)
    MYMODS:
    Pioneer Head unit in a remote location, Clarion Amp, XM Satilite Radio, 2 10" Audiobahn DVC Subs wired 1 ohm in a bandpass box, Grill Mesh, Halo Guages
  3. #73
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    Quote Originally Posted by aleromaster
    If you had read the entire thread you would have seen that these were already discussed and that condesation would be an issue.
    ATVMS.com
  4. #74
    Maximum Bitrate eCarô's Avatar
    May 2003
    SE Michigan
    Something like this?
    page 578 at McMaster.com.
  5. #75
    Nov 2003
    Valrico, FL
    Well I had read the hole thing before I just say that in a cataloge and thought i'de post it. Just forgot that it had been mentioned before
    MYMODS:
  6. #76
    Jun 2000
    Nashville
    Thanks eCar, I hadn't seen those yet.
    those are the right size, but unfortunately they are too expensive (I need 2 of them) and they draw 5A, which is ungodly.
    methinks the 80mm fans may have to suffice
    I'M DEBT FREE!!
  7. #77
    Mar 2004
    CT
    i know this isn't what your looking for at all... it's really not very on topic... but how about twin black label delta 120mm fans... they move enough air that you could just slap them on your rear bumper if you run out of gas and go
  8. #78
    Mar 2004
    Los Angles
    to stop watter and dirt from getting in the PC you can build a cold air intake system you need a small cone air filter with a 2" opening some 2" pipe hose ect. a pipe reducer and pipe that seals on the large part of the filter cone
    here is how to do it get the 2" pipe or hose and run it to the PC's intake fan the put the small cone air filter on the other end then use the bigger pipe that will seal on the large end of the filter cone make it 3" longer than the filter and drill 5-6 1" holes at the other end from the filter
    then you need to make some reeds this will let air in if the intake pipe fills with watter in bad weather and will not let watter get to the PC's intake fan
    use a scrap piece of the bigger pipe and put some car wax on the inside as mold release keep it smooth then mix some fiberglass resin and lay down 1 layer of fiberglass cloth keep it as thin as possable don't use to much resin you want the reeds to bend easy when dry so wipe off excess resin
    cut the fiberglass into 1 1/2 x 2" reeds and then drill holes and bolt them over the 1" holes with nylock nuts and bolts then use a pipe reducer and run 2" pipe to the hole in the floor TA DAA instant deep watter safe cold air intake system
  9. #79
    Jun 2000
    Nashville
    well, had it not been 45degrees today, I wouldve gotten everything done.
    I been busy:
    I get to drive around with flexiduct flapping all over my trunk till I get done.
    Why is it that it can be 80degrees here one day and have a high of 52 the next?
    I'M DEBT FREE!!
  10. #80
    May 2003
    SE Michigan
    Where are you going to put the spare tire?
  1. To heat sink or not to heat sink ...
    By jnusaira in forum Newbie
    Last Post: 02-18-2004, 09:46 AM
  2. CPU Heat question: Which one would generate less heat?
    By kiztope in forum General Hardware Discussion
    Last Post: 02-12-2004, 02:14 AM
  3. Summer heat MP3Car trial complete
    By Moose in forum General Hardware Discussion
    Last Post: 07-10-2003, 12:25 AM
  4. help with ideas for a total homebrew mp3 car player
    By acidic in forum General Hardware Discussion
    Last Post: 07-12-2002, 11:02 AM
  5. COOLING THE CARPUTER
    By moahdib in forum General Hardware Discussion
    Last Post: 07-04-2002, 08:18 AM
