Results 11 to 20 of 25
Thread: dumb question. how do you turn on the pc?
  1. #11
    Dec 2000
    Sonora, CA
    Post
    good ideas, but i only want to turn on the pc when i go on long distance trips.. so this is what i want. I want the computer to turn on automatically ONLY when the inverter is turned on by me. Then I want the inverter and computer to turn off automatically when the key is out of the ignition.
    -=Heedunk=-
    '99 Civic Si
    Electron Blue
  2. #12
    Dec 2000
    Sonora, CA
    Post
    does the autoff automatically turn off/on the pc as well as the inverter?
    -=Heedunk=-
    '99 Civic Si
    Electron Blue
  3. #13
    Dec 2000
    Sonora, CA
    Post
    this is what I want to do. please tell me if theres anything wrong with it or IF you have any suggestions. I have the auto-off module, but I dont really want to use it unless you can disable the power on function. I dont want the pc to turn on unless I am going on a long distance trip.
    -=Heedunk=-
    '99 Civic Si
    Electron Blue
  4. #14
    Jan 2001
    Adelaide, SA, Australia
    Post
    can u simply chnage a setting in your bios to boot when power is applied, I believe that some atx boards have this option.
    http://www.mp3vl.tk Plans and progress on my install - (Updated 28 June 02)
    Australian mp3car Portal
    mp3car related links Check them out / Add some
    mp3car FAQ - RTFF
    [########==]80% Assembling
    -=Current Progress: Working Sproggy supply, building box.=-
  5. #15
    Dec 2000
    Sonora, CA
    Post
    mine doesnt have that option. anyways, can someone look at my diagram and tell me if thats a good setup or not
    -=Heedunk=-
    '99 Civic Si
    Electron Blue
  6. #16
    Aug 2000
    Post
    This is gonna be kinda long (so get up and go to the bathroom in advance!!)
    ok, i guess, i should point this out... your diagram has everything coming off that acc. wire. Is that the same wire that is meant to be the remote on and off for your CD player (you know how cars have 12v constant, 12v switched and ground). ok well, if this is the same one that is going to the CD player, then don't use it to power everything else in the car. u will damage the circuit (past a certain point u will different vehicles have different capabilities)
    1.) run the tuner and the CD on the same ACC line.
    2.) run the invert on a separate line. (use a relay to turn it on and off via acc line)
    very simple wire job
    3.) depending on the LCD either (a) run it off of the psu for the computer, (b) or the line with the CD (c) or the one from the relay .
    4.) if in the future however u decide to add amps or something else, run them off the relay and not the acc line for the CD (seeing as it already has the tuner and possibly the LCD)
    now, i know some of you are thinking u have everything but the kitchen sink attached to that one wire (as i said all vehicles are different (and many American cars have more powerful electric systems than foreign) anyway, some of u may need a relay some of u may not... cost of relay $3 cost to repair the acc power in your car once u overload it more than i care to think about... an ounce of prevention is worth a pound of cure
  7. #17
    Dec 2000
    Sonora, CA
    Post
    ya i was going to wire everything to the ACC line of the cd player. I guess that would probably be too much power consumption on thast single line. i guess i can get this relay from radio shack?
    -=Heedunk=-
    '99 Civic Si
    Electron Blue
  8. #18
    Dec 2000
    Sonora, CA
    Post
    one more thing, can i have the tv tuner and lcd hooked up to the acc of the cd player and then connect the inverter and camera to the acc in the fuse panel?
    -=Heedunk=-
    '99 Civic Si
    Electron Blue
  9. #19
    Aug 2000
    Post
    what kind of LCD do u have...but, any how yeah u can run the 2 of them on that line (i am working on the assumption u have an LCD built for in car use with a 3 or 4 wire hook up)... If you have an LCD that was designed for general purposes i.e.- the $200 partsex 5" where u only 2 wires u can get power from that from your computer power supply
  10. #20
    Dec 2000
    Sonora, CA
    Post
    ya, the lcd is made for the car. its a mobile tv m5000 5"lcd. it has leads for power, ground, and accessory i believe
    -=Heedunk=-
    '99 Civic Si
    Electron Blue
  1. HU selection with CAR PC in the future...
    By Oracle in forum Newbie
    Last Post: 04-28-2004, 04:02 PM
  2. evaluate this in-dash tablet PC plan
    By dimas in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-15-2003, 07:50 PM
  3. Shutdown Controller Question
    By danl in forum Power Supplies
    Last Post: 11-22-2002, 11:19 AM
  4. Have to switch inverter off and on to power up pc
    By mbowler in forum General Hardware Discussion
    Last Post: 08-22-2000, 12:00 AM
  5. remote turn on lead from headunit to power up PC
    By BluCivic93 in forum General Hardware Discussion
    Last Post: 07-27-2000, 03:13 PM
