Results 1 to 10 of 14
Thread: Metal2Metal Glue?!?
    Mar 2004
    Metal2Metal Glue?!?
    If I need to attache two pieces of aluminum (for custom case modifications) what are my options except for welding? Is there a glue that would be about as strong? Or what other options I got?
    Thank you
    Bowel movement jjh221's Avatar
    Dec 2003
    not sure yet.
    can you drill?
    Mar 2004
    Quote Originally Posted by jjh221
    can you drill?
    I could but would prefer something that would not produce external screws
    Low Bitrate CoCa's Avatar
    Dec 2003
    Rockford, IL
    What about JB weld?
    Jan 2004
    Colorado
    I just used some JB weld on some aluminum and worked a lot better then I was thinking it would. I used a little sand paper on the surface 1st and it stuck good.
    Dec 2003
    not sure yet.
    i was just saying you could make a metal corner strip an use rivets. or jb weld i suppose, ive never tried it, let us know how it works.
    Mar 2004
    I will pick it up over the weekend, we'll post back how it turns out.
    Maximum Bitrate none's Avatar
    Sep 2003
    I've used regular old epoxy, but JB weld would be better for all metal joints.
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    Any epoxy will work but make sure to scratch up and clean the surfaces for best adhesion. Body shops glue on panels now instead of welding them.
    Fabricator
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    JB Weld would work great. I have used it plenty in the past. Just make sure to get the areas clean and slightly roughed up as suggested and then allow plenty of setup time before you go messing with it as tempting as it is. Give it extra time even. It can then be sanded or filed and then painted if you like. That stuff gets very hard.
    ATVMS.com
  1. How to glue stuff in dash?
    By SuperMatty in forum LCD/Display
    Last Post: 10-13-2002, 05:28 PM
  2. Hot glue in PCI slots
    By ppgt94 in forum General Hardware Discussion
    Last Post: 08-16-2001, 10:59 AM
