Results 11 to 20 of 30
Thread: Amp Remote Wire
  1. #11
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by webnosis
    Hi,
    Could you run a 12v supply directly from inside the PC, from one of the HDD or CDRom power connectors. This would then power the Acc line into the amp only when the PC is on. I'm sure the current draw for this is within the capabilities of the computer's PSU.
    Just a thought, shoot me down if necessary...
    Web
    Bang, you're dead!
    Did you read the above two posts??
  2. #12
    Constant Bitrate TaylorMade's Avatar
    Nov 2003
    Tampa, FL
    The accessory line is looking for 12volts. I also don't typically recommend grounding your amp at the battery unless you have a separate battery dedicated to the audio/carputer. Ground wires should be as short as possible and grounded directly to the frame of the car. Look for seatbelt bolts or something and scrub them with a wire brush. Also the thicker the better when it comes to grounding wire. Most ground wires I install are 2ft or less and are at least 8ga, if not 4. Not trying to flame knightofoldcode....
  3. #13
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    Quote Originally Posted by TaylorMade
    I agree with this philosophy as well. Basically a groundloop is created when there is a shorter path to ground than the actual ground wire. This means that maybe it is easier to ground through your RCA wires into your carpter and to ground through the power supply and then you end up with noise. Keep the grounds short.
    ATVMS.com
  4. #14
    Variable Bitrate Banderon's Avatar
    Sep 2003
    NJ
    Quote Originally Posted by sfay93
    Unless the power supply is grounded to the battery as well. If you ground everything to the battery and not the car frame, it'd be a ****load more wires, but wouldn't it also eliminate the possibility of a ground loop? Since "all roads lead to Rome"... but in this case the (-) terminal?
  5. #15
    Feb 2004
    Here is a good post on grounding for car audio:
    http://forum.sounddomain.com/forum/u...c;f=5;t=008251
    [i]"The goal here is to ground everything back to the chassis using ground points of equal (or to within .25 ohms) resistance."[/]
    Ground all your components to the same point, usually a nearby location on the car chasis. If the chasis isn't providing a good ground, then try grounding directly to the negative terminal on the battery.
  6. #16
    Feb 2004
    If you connect the ACC from a cig. lighter to your Amp Turn On, put a 500 to 1000 ohm resistor in the middle. This will ensure that only a small current will go to the Amp Turn On lead.
  7. #17
    Sep 2003
    NJ
    I advise everyone here to go vote in the thread in Comments/Suggestions that is asking the admins to put in a Car Audio forum.
  8. #18
    Feb 2004
    Omaha, NE
    Quote Originally Posted by Banderon
    All roads lead to Rome but electricity likes to take the path of least resistance.
    ATVMS.com
  9. #19
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    Ok. My cigarette lighter socket turns on when I turn the key to the acc position So that means I can use that 12v wire. With this resistor, http://www.radioshack.com/product.as...%5Fid=271-1116 (will that work?)
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
  10. #20
    Feb 2004
    Dude, you can't tell me you run a 10'+ ground wire on your amps to reach the battery. I've heard anything over 3' is a big no, no.
  1. Automotive Security
    By Maeveth in forum General MP3Car Discussion
    Last Post: 04-07-2004, 02:33 AM
  2. ME 2.0 Official Bug Reports
    By phat_bastard in forum ME Archive
    Last Post: 01-31-2004, 07:27 PM
  3. Running remote signal to amp from parallell or serial port?
    By burnout.no in forum General Hardware Discussion
    Last Post: 01-08-2004, 04:30 AM
  4. Need some help with sending audio to stock amp
    By orangewhip in forum General Hardware Discussion
    Last Post: 09-04-2003, 02:21 PM
  5. System control wire on amp
    By dudah85 in forum General Hardware Discussion
    Last Post: 09-13-2001, 09:09 AM
