Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
Thread: not able to see this page at home
  1. #11
    May 2003
    Vancouver, BC, Canada
    Hi,
    The IP address is correct when you ping. www.MP3car.com does NOT echo back the ping request so it will always time out (that's normal).
    I get the same results as you and I can see the site just fine.
    Vic
  2. #12
    Mar 2003
    UK
    so why can't i see the site... maybe my IP range is blocked?
  3. #13
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I had a similar problem when the forum style got changed, guess it was moved to a different server or domain host. I couldn't connect from home or work (both use same ISP) however when I remotely used another site it was fine. Contated my ISP and their system hadn't updated something.
  4. #14
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Surely he should be able to see the next server when he's doing the tracert?
    Try going through a proxy server such as this, 168.209.246.95 port 80
  5. #15
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Laidback
    You'd think, however I found the same thing.
    actually I just did a tracert from home and it failed after 17 hops.
  6. #16
    Phoenix Az
    It looks like there is something wrong with his connection to the internet. He should be able to at least get to his ISPs servers. If I do a tracert to www.mp3car.com it times out after 14 hops.
  7. #17
    Phoenix Az
    Actually try using FTP and see if you can get connected to a server that way.
  8. #18
    Maximum Bitrate eCarô's Avatar
    May 2003
    SE Michigan
    Search your hosts file (look for it in C:\WINDOWS\system32\drivers\etc).
    If there is a listing there for mp3car.com, delete that line.
  9. #19
    Maximum Bitrate skippy76's Avatar
    Mar 2004
    Cambridge, MA, USA
    He is resolving the IP address ok. I imagine it's an IP routing problem with your ISP.
    06 Volvo XC90
    Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
    Car PC downloads: http://carpc.harteveldt.com/
  10. #20
    Aug 2003
    San Diego, California
    that's really odd...
    umm... perhaps check your hosts file for this site? if it's there, delete it...
  1. Thread/scrolls down to the page
    By Sh0cker in forum Mp3car Forum Suggestions/Comments
    Last Post: 02-18-2004, 03:29 PM
  2. Replies: 2
    Last Post: 11-13-2003, 09:15 PM
  3. converting home lcd to mobile
    By bsostack in forum LCD/Display
    Last Post: 08-30-2003, 06:33 AM
  4. MP34home for home brew MP3 boxes
    By asteroid in forum Off Topic
    Last Post: 01-03-2002, 09:20 AM
  5. ideas for putting up content on web page?
    By Squeezer in forum General MP3Car Discussion
    Last Post: 11-12-2001, 10:58 PM
