Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 50
Thread: Fighter style MFD for motorcycle
  1. #11
    FLAC Chairboy's Avatar
    Jan 2004
    PS, it's a 1998 Suzuki Bandit 1200.
  2. #12
    Bowel movement jjh221's Avatar
    Dec 2003
    not sure yet.
  3. #13
    Dec 2003
    not sure yet.
    Someone sent me these... I was going to try to make them but i have no clue on what these mean
    Any one here have a use for this that knows how to read them. If ya make some let me know please
  4. #14
    Jan 2004
    Pardon my poor paintshop skills, but here's a rough idea of what I'd go for.
    Here are the original gauges:
    Here would be the replacement (super simple version):
  5. #15
    Dec 2003
    not sure yet.
    yeah that would look good mounted on the handle bar... is it possible to get that ap to display sideways?
  6. #16
    Jan 2004
    Since the program doesn't exist yet, anything is possible. : )
    I imagine that if we're using windows, you can use something like Pivot to set the orientation. If you're using something like linux or DOS, just develop it to display sideways or set the screen statistics in your configuration files (linux).
  7. #17
    Maximum Bitrate eugenen's Avatar
    May 2002
    Ohio
    I'd rotate your display 90 degrees so its wider side to side to better fit the area where the gauges are already. Make all the buttons on the left and right of the display, maybe duplicated on both sides so you can hit with either hand. The difficult part will be finding a display bright enough, maybe you can find a frontlit (ipaq pda style) so it will use the outdoor light. On a cycle you don't have the roof to block sunlight like in a car.
  8. #18
    Jan 2004
    The reason I was thinking of doing it vertically was because I want to emulate the look of the fighter displays and I want it to look custom.
  9. #19
    May 2002
    Ohio
    All those fighter displays are square not tall like the drawing. If you make a vertical one like the drawing it will have to be above the handlebar mounts the thickness of the display and case so it will stick up kind of high.
  10. #20
    Jan 2004
    Good point, so maybe square is better. I just don't want 4:3 if I can avoid it. Maybe instead of using a 16:9 ratio screen, I can turn a 4:3 screen sideways to make it look different.
