Results 1 to 6 of 6
Thread: Blue screen of death...
    Maximum Bitrate cadence117's Avatar
    Feb 2004
    Charlotte, NC
    So I did the install, everything is good, then all of the sudden I start getting the Blue Screen of death.....
    The carputer is in my trunk without any fans right now, Is it probable that this is the cause of the blue screen? they seem to be relating
    mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
    Total = $746....Carputer = Priceless
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    seems extremley possible
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
    Maximum Bitrate eCarô's Avatar
    May 2003
    SE Michigan
    Nah, I think most people only put fans in there for the soothing noise. They wouldn't have anything to do with BSOD, would they?
    Variable Bitrate no1knows's Avatar
    Feb 2004
    Guildford, Surrey, UK
    nah the fans are for cooling the back seat passengers, sometimes they get hot with jealousy, ive seen to pretty badly melted seats.
    Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
    Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
    CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
    http://www.no1knows.com/galleries/
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    Quote Originally Posted by no1knows
    funniest post evar!
    methinks I found a new signature....
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    I'M DEBT FREE!!
    I'm now a reasonably successful gunblogger.
    Variable Bitrate Batmanatthenewb's Avatar
    Sep 2003
    Newark, Ohio
    Quote Originally Posted by cadence117
    cadence117,
    Does your motherboard have ability to moitor temp of the cpu and the case?
    If it does, you can use the software that came with the board to monitor the temps and see if there is a heat problem. Another good software is Motherboard Monitor which you can download from http://mbm.livewiredev.com/ I have it run in the system tray. Today it was aproxx 85 degrees outside. After sitting in the sun all day the temp in my trunk was approx 118 degrees. After I fired up my system (and fans) system dropped to 109 degrees for the cpu and 93 degrees in the case. Your system is pretty close to mine, except I use inverter and 300w power supply. What is amazing is that my car pc is running cooler that my home system (case opened).
    Batman
  1. Replies: 5
    Last Post: 04-30-2004, 11:25 AM
  2. FS: TM-702L (7" in-dash screen, used)
    By audrenaline in forum Classified Archive
    Last Post: 04-28-2004, 09:19 PM
  3. What the....same screen? Good screen?
    By Seabass in forum General Hardware Discussion
    Last Post: 03-30-2004, 11:37 PM
  4. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 02:16 AM
  5. Laptop/LCD screen hookup...
    By UrbanTacticz in forum LCD/Display
    Last Post: 11-28-2001, 05:49 PM
