Results 1 to 10 of 20
Thread: Transferring data between computers
    May 2004
    I wanna transfer all my mp3s ( 29 GB's) from my desktop to my carputer. I would like to do this without burning cd's since that would take a lot of time and cds. I can't really do this over the internet since that would probably take longer. How do most people do this?
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    Personally, I have had good luck with taking the hard drive out of the car and placing it in the master computer as a slave. Drop all the MP3's in the my documents or wherever and go. Then, put it back in the car and your set. Simple and fast. Never tried a data cable but you probably dont have one if you are asking.
    2005 Ford Focus ST
    Maximum Bitrate carpcnoobie's Avatar
    Mar 2004
    Do you have a network? I put mine up on the network (had to transfer music and files from carpc to desktop). My mobo has a built in ethernet connection. I simply took a cable from there to my router, punched in a few things real quick and there it was.
    I've also done the method speed racer mentioned and that has worked well also.
    Progress Meter:
    [|||||!||||'] 95% complete
    It's in... it's finally installed!!!! But never finished!
    "It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
    Variable Bitrate Pokey's Avatar
    Tampa, Florida
    I just did the 'swap the HD' way yesterday, thats the best for that much memory, anyway else and you'll be waiting along time, like 5 or more hours.
    Dual Lilliput's 70NP/C/T
    Syntax SV266AD KT266A
    AMD Athlon XP 2000
    Viking 256MB DDR
    D-Link Wireless 802.11B
    Seagate 120GB
    OrbitMicro 250W DC/DC converter
    SII Wireless Audio Link
    Digimoto OBD-II
    Earthmate GPS
    BU-303 USB GPS
    D-Link Bluetooth
    Maximum Bitrate Yuriy's Avatar
    Jun 2004
    Seattle
    I just use the network..
    00 Saturn SL2, boosted @ 8 psi - CarDomain
    Newest install - my quickest ever
    My 2nd carputer - b4 I broke the touchscreen
    My very first carputer - voted the most ghetto
    Newbie RobMR2's Avatar
    Jun 2004
    i use a Wireless network card here
    VIA EPIA MII12000
    256Mb DDR333
    Western Digital 80Gb
    Lilliput 7" Touch Screen
    Pioneer Slot Load DVD
    PixelView Play TV Pro
    Variable Bitrate Batmanatthenewb's Avatar
    Sep 2003
    Newark, Ohio
    My car stays in the garage. Have a wireless network and wired network in the garage. Small files and updates I leave the pc on overnight (hooked to house AC) and transfer through wireless. If I am reloading or transferring a whole bunch of stuff I plug in the wired ethernet, as it is considerably faster. Either way I use Symantec PcAnywhere. Just get it started a night, and when I get up in the morning itis done.
    Batman
    Raw Wave
    Jun 2002
    Virginia
    I agree that the best way is to take the drive out of the carputer and put it in the master computer. I have about 80 gigs of MP3s and can transfer all of them in about 45 minutes. To make it ridiculously easy, go to Ebay and buy two identical hard disk trays/caddies. They should cost about $15 each. Install one in each computer. You can then just pull the tray out of the carputer, plug it into the master, transfer the files and plug the tray back into the carputer.
    Constant Bitrate fondoo's Avatar
    Rochester, NY
    i burn them on a CDRW and transfer the files to my carpc.
    May 2004
    Ok, i tried the HD swap way, but i'm probably doing it wrong. I ran the Carputer HD as a slave off the home HD. I hooked it up while the computer was off, and when i turned on the computer, it said "disk boot failure, insert system disk" or something like that. I have XP on the home comp. and windows 2000 on my carputer, and i don't have a boot disk for either. Is it a problem that they're 2 different OS?
    Also, my carpc has an ethernet connection, i think. It looks like a large phone jack right? So could i transfer data through this? Would i need a program to do this?
  1. Capture GPS data at the flip of a switch
    By Mr. Inquisitive in forum GPS
    Last Post: 02-02-2005, 07:06 PM
  2. VOICES Traffic Data
    By stevieg in forum V.O.I.C.E.S
    Last Post: 05-31-2004, 09:24 PM
  3. Online Traffic Data (UK)
    By stevieg in forum Software & Software Development
    Last Post: 04-27-2004, 03:14 PM
  4. Cold hard drive fluid bearing data loss
    By Mikesz in forum General Hardware Discussion
    Last Post: 12-13-2003, 08:17 PM
  5. Replies: 15
    Last Post: 10-21-2002, 04:06 PM
