Well, here's the PinOut of the IP BUS ( on the right )
http://www.mp3car.com/vbulletin/show...0&postcount=38
Ok, so I know it's not strictly an mp3 question (well, not even remotely!) but after hours of searching I found more references to ip-bus on this forum than anywhere else on the net so if you guys can't help, no-one can.
Here it is- I have an audi rs6 avant with the sat nav+ and boot mounted matsu****a(bless me)/panasonic 6 disc cd changer.
The nav control unit-mounted under the changer-has an aux rca input facility which I have soldered up a plug for and tested with a portable dvd player.
I have purchased a centurion 6 disc dvd changer which utilises pioneer's ip-bus connectors (in and out) I want to replace the pana changer with this but need to adapt the cable from the single multi pin pana din type cable to the ip-bus connector. When being used as a cd changer I want to retain the track control functions from the head unit rather than using the remote control so a simple audio only input conversion will not suffice.
I've looked for custom made adaptors in the uk (the satnav+ doesn't seem to be an option in the USA) Can anyone point me in the direction of complete pin out diagrams for the ip-bus and the pana din cable.
Pleeeeeeeease.
Thanks in advance
My Carputer! (More Car Pics at the end)
2 Kicker Comp 10"
Epia M-9000, 256 MB DDR, 120 Gig HD
Lilliput 7" VGA Touchscreen
Check it out?!
Cheers Pudge.
At the risk of sounding stupid, I understand the L and R pins but will the bus pins be compatible with bus pins on the panasonic?
Maybe I just expect too much?
