Results 1 to 7 of 7
Thread: Need current to flow one way
    Maximum Bitrate Yuriy's Avatar
    Jun 2004
    Seattle
    I need my current to flow only one way (this is for the laptop/battery setup).
    From what I know, I need to use a diode, like this one:
    In Russia I would normally just go to the radio market and buy a box of these, but where can I get them in US? Also, I think it might be possible to use the light diode (LED) - do any of you know if it's true?
    Any cheap alternatives?
    I'm going to disect a few of my old gadgets tomorrow and make my circuit, but I thought I'd first ask the experts what's best.
    Cheers
    00 Saturn SL2, boosted @ 8 psi - CarDomain
    Newest install - my quickest ever
    My 2nd carputer - b4 I broke the touchscreen
    My very first carputer - voted the most ghetto
    Jun 2002
    Malaysia
    diodes are quite cheap.
    In the US, visit your nearest Radio Shack if you want quick and easy.
    LEDs dont work the same way. LEDs will need a resistance in series so it doesnt blow.
    Some LEDs are bi-directional if I remember correctly
    FLAC djmickyg's Avatar
    Feb 2004
    you can use an led but u gota rember the led will use some voltage where as the normal diode wont use hardly anything
    and u can use a led without a resistor as long as the voltage is right,
    Jun 2004
    Seattle
    Well, I came up with a solution. I know there are diodes in AC/DC adapters, so I'll just disect a few
    Constant Bitrate b_nom's Avatar
    Houston, TX
    The reason LED's won't work is because they are low current devices (around 20mA) thus the need for a resistor in line for 12V use (around 600ohms resistor needed).
    You have to make sure that whatever diodes you dissect are capable of handling the current that's going to pass through them i.e. whatever your system will use, because they could heat up and eventually break down or blow up.
    WHen I was in school we use to blow up diodes in the electronics lab to stir up the teacher
    '96 Chevy Cavalier - EPIA M10000, Win2K,MediaCar, Deluo GPS Mouse with Routis, 60GB external HD, 7" widescreen monitor from DigitalWW.
    '00 Jeep Wrangler - planning stage
    What can BROWN do for you?
    Jun 2004
    Seattle
    Don't worry, I'm fairly familiar with how diodes function
    Well, I disected one of the adapters and made my little circuit - it works!
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    actually why you cannot use a LED is because of is low reverse voltage rating.
  1. Replies: 0
    Last Post: 06-14-2004, 11:36 PM
  2. Suggestions for current for a USB relay controller...
    By Zac in forum General Hardware Discussion
    Last Post: 05-28-2004, 12:52 AM
  3. EPIA Standby Current?
    By Jamez_Warner in forum General Hardware Discussion
    Last Post: 03-03-2004, 11:15 AM
  4. Using a deep cycle battery?
    By nullity in forum Power Supplies
    Last Post: 02-08-2004, 08:42 PM
  5. testing for current and AT / ATX
    By apparatus in forum Power Supplies
    Last Post: 12-15-2001, 09:58 PM
