I me doing a research paper for school on mp3's and mp3 cars. It will cover storage methods, playback methods, file transfer, and encoding. Does anybody know of some good solid sites for material?
mike
91 cadillac sedan deville, winXP, FV25 with Celeron 800, Redant 7" widescreen in dash, Opus DC-DC, Irman, Digital Cable remote(lots of buttons), 120 gig 7200rpm 8meg cache WD hard drive, VI power mobile HD rack, mediaengine
Hey I wanna see this hacked 12" in the dash!!! Do you have pics? That's gotta be a first....a crt in the dash....
As for mp3 sites, just check out everyones on the webring. There is heaps of info to give you ideas there....
or check out mine I have a link to the webring
Bj
BjBlaster! Car MP3 & Carputer!
bjblaster.com
"The solution to one problem is only the beginning of another"
I though CRT's were very bump sensitive?![]()
Not really. If they are made to industrial specs, they are fairly rugged.Originally posted by Arby:
<STRONG>I though CRT's were very bump sensitive?</STRONG>
Well mine isn't made to industrial spec, if i knock my desk, it turns blue and starts emitting a whinning sound :/
http://www.mp3vl.tk Plans and progress on my install - (Updated 28 June 02)
Australian mp3car Portal
mp3car related links Check them out / Add some
mp3car FAQ - RTFF
[########==]80% Assembling
-=Current Progress: Working Sproggy supply, building box.=-
Does it start working if you hit it again? Sounds like the solder connections where the cable connects to the board are bad.Originally posted by hornet:
<STRONG>Well mine isn't made to industrial spec, if i knock my desk, it turns blue and starts emitting a whinning sound :/</STRONG>
Its a basic 12 inch crt I got from a local computer store for $30. No problems with bumps so far. Only on one road going about 60 miles an hour do the bumps affect the picture. The Picture moves around on the screen very fluid like, but the picture is not distorted. It just moves up and down left to right about 1\4 of an inch. It might be the frequency of the bumps at that speed on that road. I simply cut the plastic away from the monitor till it fit as far back in my dash as it would go (the back of the tube hit the dash) It sits on my transmission tunnel right below the dash. I drive a cadilac deville. It has no console.Originally posted by Arby:
mike
Aaron,
One day i will pull the cover off and have a look, hitting it does make it return. Moving the cable does have some effect on it.
Im just too lasy to pull it apart![]()
mp3car FAQ - RTFF
yep, u have some loose wire.
abcd-1
