Are you using the regulation part of the ITPS or not? If not, then you're probably sending too much voltage (or not enough depending on the state of the engine) into your components, causing them to lock up.
If you want to be able to use the computer with the car off, and still using the internal power supply in the case, drop the ITPS, and get the Carnetix CNX-P1260, and hook up your screen's power to that as well as the PC. This will regulate your voltage to a constant 12V, which will stop the flickering on the screen, and it will also allow you to use the PC while the car is off, and it won't reboot when starting the engine either!
Garry
LinkBack URL
About LinkBacks
