Results 1 to 5 of 5
Thread: Autorun CF card on insert???
    Constant Bitrate Ill1's Avatar
    Jun 2004
    Woodbridge, VA
    Hello fellow car modding computer junkies,
    I have an idea that I would like to pass by a few of you. My plan is to add an autorun feature to my compact flash card. I found the below link to be very promising, but through all my trials I have not come to a proper solution. Right now I have a small exe that continuously polls the system to see if the CF card has been inserted. Then I have the program copy a few files and then check for a few other things. Getting to the point, I would love to be able to run whatever autorun.exe is found on the card once it has been placed in the reader. Has anyone done something like this? I've and for hours at work (slow day) for something that works. Hopefully someone here can shine a bit more light on this subject for me. If all else fails, does anyone know how to run a program on resume after going to standby? I was hoping that a shortcut to an executable in the startup folder would work. O well... Onto the next task
    http://www.updatestage.com/xtras/doc...autorunusr.htm
    Thanks for any help
    ILL.1
    Jan 2003
    Ruston, LA
    Scroll down your link to here:
    http://www.updatestage.com/xtras/doc...r.htm#autoplay
    Then look at the test from floppy and do the registry mod to allow autorun
    from removable devices.
    Edit: Your drivers for your flash reader will need to have support for this.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Variable Bitrate SilentAdmirer's Avatar
    Jul 2003
    Linz Am Rhein , DE
    Take a look at WM_POWERBROADCAST for Windows message for resume after going to standby
    Hope this helps
    Satish
    VOICES Status : Rework in Progress [||--------](20%)
    Preview Version at http://voices.techworldonline.com
    Jun 2004
    Woodbridge, VA
    The registry was already in that configuration. The only thing that I noticed was that the last byte was set to 91 instead of the first byte. I'll take a look into the driver for the card reader. Thanks for the help Frodo.
    If I can't get the autorun feature to work, I'll check out that WM_POWERBROADCAST message. Thanks SilentAdmirer.
    I'm sure I'll find a solution here in the near future.
    ILL.1
    Jul 2003
    Linz Am Rhein , DE
    also chk WM_DEVICECHANGE I use it for USB flash memory
  1. Autorun on a memory card (digital camera)
    By d_sellers1 in forum General Hardware Discussion
    Last Post: 07-02-2004, 02:16 AM
  2. Anyone using CF card as boot devices
    By mpattonm in forum Software & Software Development
    Last Post: 04-10-2004, 06:10 AM
  3. Flash Memory Speeds? (CF & SD cards)
    By eCar™ in forum Off Topic
    Last Post: 03-25-2004, 01:11 AM
  4. FS: Slimline CD & DVD, 512MB CF Card
    By StratusPh34r in forum Classified Archive
    Last Post: 01-31-2004, 09:31 PM
  5. help - video card problems
    By Cliff in forum General Hardware Discussion
    Last Post: 04-15-2002, 06:25 PM
