Results 1 to 10 of 16
Thread: Help make a LAN (err WAN)
    Maximum Bitrate EBFoxbat's Avatar
    Jun 2004
    Massachusetts
    I'm moving out of my house. I'm moving about a mile away (a mile as the crow flies.)
    Instead of shelling out $42 a month for local broadband, I figure why not just extend my parents network (err their $42 a month) to my new appartment?
    If I were to mount some high-gain, directional entennas on the roofs (which I am able to do) I would be skimming the tree tops.
    Is it doable with off the shelf parts? Or should I look forward to my own $42 a month?
    I figure directional would be most efficient, but I certainly wouldn't mind flooding 1/2 my town with 802.11... cloked, WEP and MAC locked, but it would me use my carputer near my house, which is fun. Thoughts??
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    It may be doable with some homemade or even store bought antenna's. Do a google for Wi-Fi antenna's, you should find a lot of info.
    Here's a start
    http://www.turnpoint.net/wireless/cantennahowto.html
    Maximum Bitrate Seth's Avatar
    Jun 2004
    Athens Greece
    Lots of gizmos here
    Variable Bitrate blurp's Avatar
    Sep 2003
    Hampshire, TN
    www.bradleyjacobs.com
    There is more stupidity than hydrogen in the universe, and it has a longer shelf life. -- Frank Zappa
    Constant Bitrate jaeger's Avatar
    Jul 2004
    Galveston Is., TX
    poor man's wifi antenna http://www.usbwifi.orcon.net.nz/
    this is a link i stumbled across
    nine.
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    I have installed 3 mile WiFi antenna's for a customer they were using it for about a mile and it worked pretty good, very picky about line of sight though. but they antenna's were very expensive I would see if you can build your own.
    Dec 2002
    Illinois
    I remember people using an old primestar antenna and a tin can to send and recieve a signal. It's probably in one of the links above, but thought I'd chime in.
    actually why waste you money when you can use cookware people sure are creative. Or even a pringles can
    Jun 2004
    Massachusetts
    I just dont know. It seems like the trees will be a big problem... as they scatter wifi like it's their job.
    ,./(0)3
    May 2004
    Northridge CA
    Quote Originally Posted by EBFoxbat
    lol!
    well one mile is very doable.
    i read an article about a guy who was able to go 10 miles he bounced the signal off a mountain where he put in a repeater.
    Dec 2003
    Michigan
    Per slashdot... 55.1 mile wifi, unamplified (except the parabolas of coarse) using 2 old 8 foot dishes. http://www.wired.com/news/culture/0,...w=wn_tophead_2
    As a side note, I've used the cantenna (the one sold to be similar to the pringles can) and it sucked. The pringles can is acutally a yagi being focused by the can, the cantenna is just a dipole being focused by the can so stay away from the cantenna people. Also, at work here, we have a 6 mile 2.4 ghz connection using two 24dbi flat panel dishes (VERY expensive) and they work great, but are very picky about alignment. Just keep in mind that as the gain goes up, the tolerence for mis-alignment of the two "dishes" goes down. Good luck!
    2006 Chevy Colorado: VIA M10000 EDEN, 1 GB RAM, 80 GB 2.5" Seagate HDD, USB Slim Slot DVD/RW, Holux GPS, MobileVU 10.4" LCD (touch not working yet), VOOMPC Case (blue), 70W DC-DC supply.
  1. want to make opinion poll abiout carmp3 /multimedia systems
    By felix99 in forum General MP3Car Discussion
    Last Post: 07-15-2002, 06:45 PM
  2. Is it possible to make a HUB yourself ?
    By Raas in forum Off Topic
    Last Post: 12-20-2001, 03:40 PM
  3. Have your friends make their own playlist!
    By dudah85 in forum General MP3Car Discussion
    Last Post: 08-14-2001, 11:19 AM
  4. make dir a playlist?
    By etrik in forum Software & Software Development
    Last Post: 02-26-2001, 06:00 AM
  5. how to make LED flash?
    By schrodos in forum General MP3Car Discussion
    Last Post: 01-14-2001, 07:39 PM
