Results 1 to 3 of 3
Thread: Car voltage problems
    Variable Bitrate cheerio's Avatar
    Jun 2004
    San Antonio
    Angry Car voltage problems
    I have been having transmission problems with my car, and i got it 'fixed'. But now my check engine light is back on, and i took it back and they said its fine, the transmission problems now is a low voltage problem, easily fixable. I got a 2nd opion on this, so i believe it for now. Right now i have a xplod 600 watt 4 channel amp, pioneer head unit 52watts(but not in use), and a 300 watt alpine amp for my 2 12s". I was thinking abotu getting another battery and wireing them together, but i dont have the room under the hood for this. Would a high current output altinator be a better option? What do yall reccommend?
    Low Bitrate l9nux's Avatar
    Aug 2004
    Sussex, UK
    Thumbs up
    It's always a good idea to get a high current alternator, and depending on your car, you may be able to find a second hand one out of a diesel, or larger engine car. If you don't have room to add a second battery then a good battery such as the Optima (www.optimabatteries.com) will be an excellent replacement for the existing one.
    -= I took the red pill =-
    Mar 2004
    Montreal, Qc.
    Getting a bigger alternator could be quite expensive. If you have the cash why not.
    But I would suggest making a tank circuit with an extra battery in your trunk just for your amps. Just do a on the forums for "tank battery" or "tank circuit" (without the quotes). The optima battery is excellent for the tank circuit because it's a gel battery and it's much better then a regualr acid battery.
    I have the same issue, I have 2 AMPS powering 2-10", 2 6X9's, 2-4" and 2 tweets. And I'm thinking of doing the tank circuit for my amps.
    Hope this helps.
    VWMAN
    "Live Long And Prosper"
    car: VW Cabriolet '90
    puter: M10000(toasted), Lilliput, CarNetix
    status: In Progress
  1. For Sale for all you aussies. Complete mp3 car pc
    By Holden__V8 in forum Classified Archive
    Last Post: 04-09-2005, 06:30 AM
  2. ITPS problems
    By numberone in forum Power Supplies
    Last Post: 10-29-2004, 05:07 AM
  3. Epia M10000 + PW70a + car startup
    By SuperSonic in forum Power Supplies
    Last Post: 11-27-2003, 03:21 PM
  4. Car Stereo Installation Video's for Sale
    By johnram in forum Classified Archive
    Last Post: 09-05-2002, 11:27 PM
