Results 1 to 10 of 13
Thread: Hibernate and standby grayed out?!?
    Jun 2004
    Savannah, GA
    I"m almost to the point of installing my system so I was getting the computer ready(installing XP, loading mp3s, etc) but for whatever reason the option for hibernate and standby is grayed out from the shutdown menu. I did some of the registry tweaks floating around the forums so maybe I did screwed up something there. Also in frodoplayer neither hibernate or shutdown work, I'm assuming because of the dependencies. Should I reinstall XP? Clean install? Is this something in the registry?
    Is it a BIOS setting? These are the settings I'm using.
    ACPI: [S1&S3]
    HDD Powerdown: [Disabled]
    Power Management Timer: [Disabled]
    Video Off Option: [Suspend -> Off]
    Power Off by Power Button: [Instant Off]
    Run VGA BIOS if S3 Resume: [Auto]
    AC Loss Auto Restart: [On]
    System Specs:
    Epia M10000
    300W ATX PSU(for in home testing and set up, hibernate works with other computer using this PSU)
    Windows XP
    Kefka_Killer.owns(you);
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    are all the proper drivers installed?
    Check device manager and see if anything is screwy.
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    Total spent on wedding so far: $3885.79
    Thanks to everyone for your support.
    I'M DEBT FREE!!
    Maximum Bitrate cadence117's Avatar
    Feb 2004
    Charlotte, NC
    sometimes you have to enable it in windows...
    control panel> Poweroptions
    mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
    Total = $746....Carputer = Priceless
    Jun 2004
    Savannah, GA
    Quote Originally Posted by cadence117
    I forgot to mention that part.
    Power Scheme: Select power profile, turn off monitor, and turn off hdd
    Advanced: show icon, when power button is pressed(shut down, restart, nothing)
    UPS: None
    Quote Originally Posted by wizardpc
    No red exclaimations, but two yellow questions for USB controller and Video controller. I doubt these are the problem but I'm gonna get the drivers off Via's website in a sec.
    Maximum Bitrate falconey's Avatar
    Feb 2004
    Atlanta
    It's the video controller I just had the same issue. You need the drivers for the vid controller installed.
    Jun 2000
    Nashville
    Quote Originally Posted by kefka_killer
    thats gonna be the problem. make sure you update both the Video and USB, and get the latest SP1 updates as well
    I'M DEBT FREE!!
    Jun 2004
    Savannah, GA
    Quote Originally Posted by falconey
    Quote Originally Posted by wizardPC
    Well I guess thats the general consensus, I didnt get a chance to update last night, I got sidetracked, but when I get home from work I'll update those drivers. Does anyone know why this is the problem though? I would think that the updated drivers were an unrelated issue, esp. since both usb and video still work. Thanks for all the replies.
    Variable Bitrate therussman2002's Avatar
    Mar 2004
    Milwaukee, WI
    Yeah i had this exact problem when i made a stripped down XP cd with nLite. Those options were greyed out till i installed my video drivers and rebooted.
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    As well as installing the rest of the drivers, make sure under Computer in Device manager, that it's set to ACPI Uniprocessor Machine.
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Jun 2004
    Savannah, GA
    I got all of the drivers installed, no conflicts in device manager, and Standby now works however hibernate is still grayed out. Alternatively, should I just use standby since I am using an opus 90W which has a battery management feature which will prevent the battery from draining?
    Confused: Yes ACPI PC is under Computer in device manager.
  1. EPIA video + Winamp standby problem
    By crisr in forum General Hardware Discussion
    Last Post: 08-25-2004, 07:16 PM
  2. What's the difference between Hibernate and Standby?
    By BriCubz in forum General MP3Car Discussion
    Last Post: 08-17-2004, 10:32 PM
  3. Desktop Button for standby or hibernate?
    By gospeed.racer in forum Software & Software Development
    Last Post: 04-27-2004, 03:33 PM
  4. Man, no luck with hibernate and standby modes - both are crashy any tips?
    By psyclobe in forum Software & Software Development
    Last Post: 12-23-2003, 11:28 AM
  5. Standby or Hibernate
    By FalconPR in forum General Hardware Discussion
    Last Post: 03-21-2003, 01:20 AM
