Results 1 to 8 of 8
Thread: Common Auto Voltages
    Maximum Bitrate EBFoxbat's Avatar
    Jun 2004
    Massachusetts
    I'm working on a new startup controller.
    Can someone suggest common car voltages? I mean, if I were to play with my car and a multimeter, what would I find? Obviously 12v, but interior lights, horn, alarm/security systems, stereo equipment (stock) are there any other common voltages found in cars?
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
    Top Ramen lgbr's Avatar
    Feb 2004
    Spokane, WA, US
    Engine on - 14.4 Volts
    Engine off - 12 Volts
    Engine starting - 7-12 Volts
    Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
    Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
    Head units are for cheaters!
    sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
    Variable Bitrate RS3RS's Avatar
    Aug 2004
    Springfield, MO
    Quote Originally Posted by lgbr
    Yup.
    Jun 2004
    Massachusetts
    Interior lights? Alarms?
    ,./(0)3
    Aug 2004
    Hudsonville, Michigan
    Interior lights, alarms, hell even a starter are built to handle a range from 9 to 16 or so volts
    Nate
    I know what yer thinkin...did he fire six shots or only five...
    Feb 2004
    Spokane, WA, US
    I don't know of cars requiring any regulated voltage anywhere, so I guess around the whole car you'll find the same voltage as at the battery.
    However, there is probably a resistor or something on the headlights/turn signals.
    Maximum Bitrate carpcnoobie's Avatar
    Mar 2004
    There are some devices that use six volts. Many of the ranges that the engine computer reads (engine sensors) go at a zero to five volt range. Some hall effect sensors go zero to seven. The basic stuff runs pretty much 12 volts, but if you're looking into sensors and ECM controlled devices, the voltages may vary.
    I know sometimes windshield wipers use 6v for low and 12v for hi. The fan blower has resistance for different fan speeds. Obviously spark has a boatload of voltage. I'm sure there are more I'm not thinking of.
    Progress Meter:
    [|||||!||||'] 95% complete
    It's in... it's finally installed!!!! But never finished!
    "It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
    Variable Bitrate Superduck's Avatar
    Oct 2003
    Vancouver BC
    The regulator in the alternator is set at 14.4v. I had a customer that had a faulty regulator, which fed over 18 volts into his whole electrical system. He had to replace almost every bulb in the truck, as well as half the electronics.
    And for nitpicking sake, car batteries usually have six plates, at 2.1v per plate, making for 12.6v at a full charge. You can see the six plates in an Optima "Six-pack" battery.
    Cheers,
    Kris
    How Much Horsepower Can I have And Still Go To Heaven?
  1. Auto DJ function proposal.
    By kid320 in forum Media Engine
    Last Post: 07-26-2004, 06:35 PM
  2. Auto DJ function proposal... opinions?
    By kid320 in forum Software & Software Development
    Last Post: 07-26-2004, 11:07 AM
  3. 7" dscustoms lcd auto turn on?
    By icet in forum LCD/Display
    Last Post: 05-14-2004, 12:48 PM
  4. voltages
    By marsjell in forum Power Supplies
    Last Post: 06-03-2002, 12:04 PM
  5. Winamp auto start of visual plugins!
    By Norman in forum Software & Software Development
    Last Post: 03-10-2000, 04:05 PM
