Results 11 to 20 of 30
Thread: 50 pin laptop->IDE convertor?
  1. #11
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    Well, it certainly LOOKS like a CF interface, but we have no way of knowing its pin-compatible. Do a and see what the interface specs are, if its CF then an IDE/CF adapter could be modified to work.
    Edit: Its a 1.8" Embedded HDD for MP3 players etc. Specs here: http://www.toshiba-europe.com/storag..._Datasheet.pdf
  2. #12
    Jun 2004
    ***Other than the differences in voltages, 3.3 v versus 5.0 v for 2.5 inch drives***
    It looks like it has the same pin size and pitch as laptop 44 pin, and looking at the specs for the drive at the Toshiba site, it APPEARS to use the same pinout as 2.5 laptop 44 pin drives. http://sdd.toshiba.com/main.aspx?Pat...00659c00000641
    And it should be noted that 2.5 drives are actually 50 pin also. 44 data, 2 missing, then 4 for the Master/Slave/CS pins. 50 total. Just use those gender changers someone else posted above (I got them for a buck a piece for each row, two required).
    I haven't played around with a 1.8 inch drive yet, but I have been using laptop drives in a couple of different systems that have required me making cables with double ends and flipping them, and using the gender changers. I don't know how to deal with the different voltage requirements/uses.
    http://www.ddknet.co.jp/us/products/...d_d/index.html might be of some use also.
  3. #13
    So to summarize, I just need to get a 50 pin gender changed and use an existing laptop->IDE convertor? I thought they were only 44 pin? Is the pin out of a 2.5" laptop drive really identical in size to the pin-out on this drive (not having one to compare to, I don't know the answer to that).
  4. #14
    Mar 2004
    so what is this drive exactley called what are the sizes of the drive 40 18 120 gig where can you get these ebay?? direct from the manufacture??
    i want to tag along with this and see wht you come up with to use this drive
    thanks
    chad
  5. #15
    Jun 2004
    Actually, after some easy quick google searches, it looks like the pitch is 1.27 mm for the 1.8 inch drive IDE, 2 mm for 44 pin 2.5 inch drive IDE (and 2.54 mm for 40).
    A little google time, and going to the drive manufacturers web page brought up all this information pretty quickly and painlessly.
  6. #16
    pitch?
  7. #17
    Jun 2004
    Quote Originally Posted by Arathranar
    pitch?
    spacing between the pins. 1.27 mm is the pitch, .05 inches, which is what CF is. You can find the pin assignments for CF also. With the 3.3 v requirement, it seems more and more like it is a CF interface. I don't really know, I looked into these drive a little because my project would be way better with these over a 2.5 inch drive, but cost and availability, as well as all these unknowns knocked them out of the running for me using them.
  8. #18
    Banned Motorcity's Avatar
    Apr 2003
    Detroit, MI
    Your hard drive is ATA-5 interface. SPEC
    you need the connector board as shown in my picture, and attach to this adapter here.
    seems a pretty expensive route to take.
  9. #19
    Maximum Bitrate Don 944 LA's Avatar
    May 2004
    San Diego / Los Angeles
    That looks like an EARLY PCMCIA to CF adapter..
    how about just using a CF to IDE adapter
    I could be wrong on what you currently have, any "close up " pics ???
    man, pics get " ***** " in url
    here's one
  10. #20
    May 2004
    and another
  1. Laptop 2.5" HDD adapter, 44 pin-40 pin
    By Jimbo1978 in forum General Hardware Discussion
    Last Post: 09-15-2004, 12:00 AM
  2. 50 pin to 40 pin connector for cd drives, supplier?
    By ruflyf in forum General Hardware Discussion
    Last Post: 03-11-2004, 11:23 PM
  3. 50 pin IDE DVD
    By Alphared in forum General Hardware Discussion
    Last Post: 01-09-2003, 12:15 PM
  4. So I cant get my simple LCD to work... :(
    By sirhotalot in forum LCD/Display
    Last Post: 08-16-2002, 10:57 AM
  5. Replies: 2
    Last Post: 10-07-2001, 11:43 AM
