Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: should 1ghz / 260MB be enough to run video?
    Illinois
    I got the via 800 or something mobo, i forget which one. Anyway, its 1ghz and i got 260MB ram. But I converted my simpsons episodes into DIVX format, but when I go to play them, the sound runs and normal speed, but the picture is slow.
    I tried running some smaller video files that are like 10-20 seconds in length and those run fine.
    Do i need for RAM?
    Jun 2004
    If it is an Epia 800, then it is an 800 mhz machine. Even the new M10000 1 gig machines can't play most DIVX encoded movies with the newer higher compression. the newer M series have more horsepower even at the same clock speed as the original Epia. I have the ME6000, and it blows away (okay, its all relative) the Epia 800 I played around with that made me realize I needed a more current M series board (but wish I could have waited for the SP).
    Constant Bitrate SniperXX's Avatar
    Oct 2004
    Southern California -- Diamond Bar/Walnut Area
    DivX always lagged on older VIAs. I got a 733.... So its not going in to my project for that reason, laggy video.
    Illinois
    Quote Originally Posted by Bangster
    well under Windows System it says 1.0Ghz. So adding ram wont help? Its the processor thats holding me back?
    Super Moderator xBrady's Avatar
    USA
    Quote Originally Posted by nappyjim
    Yes, adding RAM helps.
    Installed.
    -GPSSecure- - GPS Tracking
    FLAC jbors's Avatar
    Nov 2003
    Bangster is right. If you have V series it won't help you as it uses SDRAM. All M use DDR which is why they outperforms. I play everything on my ME6000 including DVDs with no more than 60% load.
    FLAC ppgt94's Avatar
    May 2001
    USA
    I can run dvd and divx 5 (windows media player classic) on my Compaq Presario 4840. It was a 266Mhz PIII 192MB running Windows 95b. I don't know why a 700Mhz couldn't.
    Constant Bitrate Adam432823's Avatar
    Nov 2003
    S.F. Bay Area
    I have a Pentium 1000 with 256mb ram and the built in intel 715 video chip. Divx and Xvid work just fine. Maybe faster disk drives? Do you have a ton software running in the backgroud (spyware, viruses, other crap you don't need...)?
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    I have an EPIA 800 in a VCR that I use for all my movies and stuff. DivX I have no problem with. Some XviD movies I do have a bit of lag though. But My DivX and 3ivX movies work great. I have 256mb ram runnin XP pro with sp2. Back when I had ME on it, all my movies worked just fine. What OS you running?
    Tidder
    Try RevFE
    May 2004
    I did have a Epia 600mhz with 256mb ram and it did have a few peoblems with video. I dont know why, becase I swap it to M10000 before I could get the answer. I 'was tould that i should have 1GHz.
  1. Glitchy video when gps running. . . help!
    By PaPP in forum FrodoPlayer
    Last Post: 08-12-2004, 10:42 AM
  2. Video card with Component outs/ins?
    By the_new_guy in forum LCD/Display
    Last Post: 08-04-2004, 05:42 PM
  3. video not working in windows
    By blackpacu in forum General MP3Car Discussion
    Last Post: 07-29-2004, 06:56 PM
  4. Divx video playback
    By mindtool in forum MediaCar
    Last Post: 12-08-2003, 06:19 PM
  5. video problem
    By mp3edneon in forum General Hardware Discussion
    Last Post: 07-23-2001, 01:30 PM
