Results 1 to 8 of 8
Thread: C++ Programming Help
    Variable Bitrate egeekial's Avatar
    May 2004
    Ok, I need some help with my C++ homework. I'm not asking anyone here to do it for me... that would defeat the purpose of taking the class. I just need a little bit of help understanding and doing some things. If someone could AIM or ICQ me, that would be great It's all very basic stuff, but I'm just a newbie to programming.
    AIM: morgan196
    ICQ: 43581290
    May 2004
    It's a bit lengthy... but here it goes.
    Here is the problem:
    Using the getDouble function as an example write your own function readMoney, which reads amount of dollars and cents from the user. The user input should be in the form:
    $123.34
    That is, it should start with the dollar sign, and then it should have the amount of dollars, then the decimal point, and then 2-digit amount of cents. It should end with any space symbol or a dot. Your function should return 2 integer values (one for dollars and another for cents).
    Here is getDouble:
    #include <iostream.h>
    #include <ctype.h>
    #include <stdlib.h>
    // function: getDouble
    // goal: The function reads character by character from the
    // standard input (cin) and converts them into a floating
    // point number. It stops when it reads any character
    // but +, -, decimal point or a digit.
    // As the result it returns the number read.
    double getDouble(void)
    char ch;
    int sign = 1;
    double res = 0;
    double factor = 10;
    cin.get(ch); // read the very first symbol from the user
    // check if the first symbol is a sign
    if( ch=='-' || ch=='+' ){
    if( ch == '-' ) sign = -1;
    cin.get(ch); // read the next symbol
    // repeat the loop while it's a correct symbol
    while( isdigit(ch) || (ch=='.' && factor>0.1) ){
    if( isdigit(ch) ){
    if( factor > 0.1 ){
    // we haven't read the decimal point yet
    res = factor * res + (ch - '0');
    else{
    // we have read the decimal point by this time
    res += (ch - '0') * factor;
    factor /= 10;
    else{ // we just read the decimal point
    factor = 0.1;
    return res*sign;
    int main(void)
    double num;
    cout<<"Enter a floating point number ";
    num = getDouble(); // using the new function to read the user's input
    cout<<"You entered: "<<num<<endl;
    return 0;
    My question is how do I output dollars and cents from the function as separate variables.
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    I won't tell you exactly how to do it, but I'll give you your first clue, first convert you double for dollars into cents represented as an integer. It should then be an easier problem to solve. YOu just have to figure out how many cents are in a dollar then and how many remaining cents you have after you subtract out the whole dollars.
    Hint: The modulus operator (%) is your friend.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Super Moderator xBrady's Avatar
    USA
    Are you asking how your function can return two seperate values? As in this case, two integers?
    Installed.
    -GPSSecure- - GPS Tracking
    May 2004
    This is what I'm going to do:
    void readMoney(int &dollars, int &cents)
    Now I just have the problem of trying to input as one variable and break it down into 2... man, I hate doing this >:/
    May 2004
    I can't get the cents to work right...
    My code so far:
    #include <iostream>
    #include <stdlib.h>
    using namespace std;
    char money;
    double factor = 10;
    cout<<"Enter amount of money$: ";
    cin.get(money); // read the very first symbol from the user
    // check if the first symbol is a dollar sign
    if( money == '$' ) cin.get(money); // read the next symbol
    else cerr<<"You did not enter a dollar sign ($).";
    while( isdigit(money) || (money=='.' && factor>0.1) ){
    if( isdigit(money) ){
    if( factor > 0.1 ){
    dollars = factor * dollars + (money - '0');
    else{
    cents = (money - '0') * factor;
    cout<<cents;
    factor /= 10;
    factor = 0.1;
    cout<<"Amount in the function: "<<dollars<<"."<<cents<<endl;
    int main(void)
    int dollars=0, cents=0;
    readMoney(dollars, cents);
    cout<<"Amount in the main: "<<dollars<<"."<<cents<<endl;
    system("PAUSE");
    return 0;
    Oct 2003
    Toronto, Canada
    '0' is a character. I dont think you want to perform arithmetic with ints and chars
    VIA Epia II
    256MB 266DDR Ram
    90GB Wester Digital
    Bluetooth/Deluo GPS
    Lilliput 7" Touchscreen
    Mazda 6 Carputter > Click Me!
    Jul 2004
    Rancho Cucamonga, CA
    I think you are making this harder than it looks once you check to see if the first character is a dollar sign then you should be able to call your getdouble function and it can do the rest of the work of getting the number input and converting.
    Hope this helps
    EPIA MII-1200, 512 MB Ram, Seagate 7200 RPM 160GB hard drive, Orinoco Gold with 5.5 dB external antenna, Lilliput 7" TS, DVD-ROM, M2-ATX, Rikaline 6010 GPS, Running Frodo Player
    My Truckputer
  1. Wanting to learn some programming, help me pick a language!
    By RS3RS in forum Software & Software Development
    Last Post: 10-15-2004, 05:38 PM
  2. C++: GUI Programming with >NET Framework
    By [iG] in forum Software & Software Development
    Last Post: 05-24-2004, 07:57 PM
  3. A bit off Topic on Programming
    By xanimal in forum Software & Software Development
    Last Post: 04-21-2004, 09:27 PM
  4. batch file programming LCD's
    By mosh in forum LCD/Display
    Last Post: 05-19-2002, 01:55 AM
  5. Need to start somewhere with Hardware programming
    By 168db in forum Software & Software Development
    Last Post: 01-11-2002, 09:35 AM
