Results 1 to 7 of 7
Thread: Removing super glue and bondo.
    Illinois
    While working on putting my monitor in the dash, some super glue leaked over and dripped onto my dash. So now i have an ugly white streak going down. I tried nail polisher removed, but it didnt do any good. Any other suggestion?
    Same thing with bondo. A little bit dried on the dash. When i run my hand over the spot, i cant even feel a hump or anything, its just a little white mark. What can i use to remove that?
    Low Bitrate Prem's Avatar
    Oct 2004
    West Sussex UK
    Chances are they have damaged the surface of the dash.....
    Bummer....
    Raw Wave
    Jun 2003
    You may wanna try this :
    http://www.maplin.co.uk/Module.aspx?...ID=9&doy=30m10
    I have never used them before but it may do the job.
    Constant Bitrate RPI Geek's Avatar
    Oct 2004
    Schenectady, NY
    In my experience, superglue actually removes the color from certain plastics. If you can't feel it, that's probably what happened. Try getting some paint if you don't have any luck removing it, and put a dropcloth down next time.
    Old plans out the window because of an accident .
    Have: M1-ATX, EPIA M10000, 256MB, 60GB 2.5", slim slot load DVD
    Need: Time, HU integration, ideas for Lilli
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Sand it down, smooth it out, paint it. Easiest way and you'll get good results.
    Tidder
    Try RevFE
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    what color is your dash? i have the same problem but its like shows in the grain so im thinking about using some model paint and thinningit a little then almost white washing it over the spots ill try it later today or tomarrow and tell you how it goes awel as pics.
    Illinois
    my dash is the "stock" flat black color. its plastic
