Page 1 of 5 12345 LastLast
Results 1 to 10 of 42
Thread: Customizing the "Resuming Windows" screen
    Nov 2004
    I was just wondering if there was a way to customize the "resuming windows" screen that the computer displays when resuming from hibernation.
    I'm pretty sure it would be impossible to get an image to display there but I remember how we used to search through the old Win95 executables to change what the start button said... so is there a way to figure out where windows reads the "resuming windows" text and change that to something cool (ie: resuming carputer, etc).
    Jun 2004
    The North, Manchester
    try:
    Boot Skins!!!
    I dont know if it changes the Resume screen but it will change the loading after power on screen - dunno if they are the same?
    Nick
    Jun 2003
    Memphis - TN
    Not the same thing.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    Jun 2004
    oops
    Nov 2004
    Any ideas about the hack so I can change what the "resuming Windows" line says? What about using a program like resource hacker to find what dll has that text and then changing it. Anyone know what file that text would be in anyways?
    Jan 2003
    Ruston, LA
    Quote Originally Posted by davem
    NTOSKRNL.EXE
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Nov 2004
    Thanks Frodo.
    So I have to use a hex editor to see that? Can I just change the corresponding text and everything work fine?
    Jan 2003
    Ruston, LA
    Thanks Frodo.
    No, it's not quite that simple. Use a resource editor. And you'll have to save
    a copy, and change some boot.ini options etc.
    You'll have to
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Keep us updated on your progress
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Actually the "Resuming Windows" text is stored in the file C:\NTLDR
    You can simply change this with a hex editor ("Resuming Windows" is at offset 35990)
    I changed mine to read "Returning to car..." and then removed all the other text that says "Press F8 to blah blah"
    PS: You sound like you know how to use a hex editor, but just incase - Make sure the text you want is less or equal to the length of the one you're changing, or you'll corrupt the file. If you use less characters, replace the left-overs with spaces.
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  1. Replies: 5
    Last Post: 04-30-2004, 12:25 PM
  2. What the....same screen? Good screen?
    By Seabass in forum General Hardware Discussion
    Last Post: 03-31-2004, 12:37 AM
  3. Gamecube screen
    By junior in forum LCD/Display
    Last Post: 11-24-2003, 07:38 AM
  4. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
  5. Redant screen - widescreen, screen res, TV out???
    By Griffin_Dodd in forum General Hardware Discussion
    Last Post: 02-06-2002, 07:09 PM
