Results 1 to 4 of 4
Thread: Heat insulation
    Variable Bitrate ryuandwings's Avatar
    Nov 2003
    TN
    Heat insulation
    I have my set up in the console area and just today I realized
    that there is a duct where I have my setup.
    It was good for summer time, but not so good when I turn on the heater.
    I am looking for insulation sheet or something I can put over
    the duct. I see lot of sound deadening sheet with aluminum,
    would that work for heat also? I could not really find anything for heat.
    I have limited space in the console so the insulation can't be too thick.
    Any suggestions?
    Tainted Love Cris's Avatar
    Romania
    I don't think you'll have any problems...
    [QUOTE=ryuandwings]
    would that work for heat also?QUOTE]
    ummm... metal is a great conductor of heat, alloys make up superconductors. Putting a sheet of aluminium will aid with the heat transfer, making it worse. I wouldn't of thought you would have had a problem, but if you are really worried the only way is to redirect the heat. Either cut the duct short, or add to it and channel the airflow away. You could try something like a small piece of loft insulation or pipe lagging, but I doubt it will help that much.
    Nov 2003
    TN
    Quote Originally Posted by Matthew230
    That is a good point, I don't know what I was thinking... I guess I wasn't.
    After thinking for a little more, I may put a sheet of foam insulation kind like plumbing pipe insulation. It may not help much or may not need at all, but that will make me feel better.
    Thanks guys for replys.
  1. Melbourne Heat...
    By Fox_Mulder in forum Off Topic
    Last Post: 10-19-2004, 04:59 AM
  2. To heat sink or not to heat sink ...
    By jnusaira in forum Newbie
    Last Post: 02-18-2004, 10:46 AM
  3. CPU Heat question: Which one would generate less heat?
    By kiztope in forum General Hardware Discussion
    Last Post: 02-12-2004, 03:14 AM
  4. Summer heat MP3Car trial complete
    By Moose in forum General Hardware Discussion
    Last Post: 07-10-2003, 01:25 AM
  5. COOLING THE CARPUTER
    By moahdib in forum General Hardware Discussion
    Last Post: 07-04-2002, 09:18 AM
