Page 1 of 5 12345 LastLast
Results 1 to 10 of 43
Thread: carputer install: I dare you...
    Low Bitrate Cat Monkey's Avatar
    Nov 2004
    Kildare Ireland
    i've started reading this forum (for 6 curious months) and I have to say im actually dreading installing the thing for the first few time given the number of horror stories on this forum. I'm waiting for the screen and have spent considerable money at this point so failure mustn't be an option.
    I'd like to call out to all carputer owners who can say 'I did it and it worked and has been working flawlessly for x number of months'
    No opus started winking at me, lilliput put on a face, windows ****ed on my seats or the via poohed in its own case
    Who has done it and is living the dream. A carputer that works and has been working for a while. Does such a thing even exist?
    With so many separate devices all running together I'd imagine the likelyhood of reliable harmonious operation is small. so please prove me wrong. And if I'm right why do we do it? is there somthing wrong with carputer people? are they mentle? do they wake up in the morning and think carputer? do they walk into an electronics strore and find it difficult not to start thinking about carputer? does their woman hate carputer (cause it dosn't work)? do they not have a woman because of carputer? do they care (they have carputer after all)? do they find it hard to listen to other people in the car for thinking about carputer?do they check frodoplayer sub-forum hourly for a new release? when carputer is finished are they in denial and say 'carputer is never finished'? is carputer ever finished?
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    My set up has evolved over time and had a few hicups, (when I change stuff, and nothing bad)
    My PS always works, The screen is great. The keypad is fine. I have a simple set up:
    Celeron 300a integrated MB, Desktop HD, a keypad and 14 inch LCD desktop. I only play music and use W2k as an OS.
    My deck has RCA AUX in so that is simple also.
    Parts of the system have been in use for more than 4 years, no PC hardware failures. The drive has the longest service time.
    TruckinMP3
    Read the FAQ!
    Low Bitrate Insight's Avatar
    Know how you feel. My video-out stopped working, touch-screen died, DVD drive fried but honesty its about preserverance on this one. You have to stick it with it.
    CarPC
    VIA Nehemiah M10000, 256MB RAM, 40GB HDD
    100W DC PS /w ITPS, TV tuner, Slim Slot-Load DVD
    GPS, Streets and Trips 2004, Rearview Camera
    Bluetooth, 802.11b & CDMA 1X
    In-dash 7in Lilliput Touchscreen
    May 2004
    Texas
    i had my system up for 5 months now, i had some problems but nothing that i would consider bad. i am running a regular 5.25 hard drive with a inverter and a shutdown controller ,no problems with the drive or the inverter, the only thing i added to the inverter was a surge protector with EMI protection between my pc and the inverter to eliminate a tiny noise problem ,it is now noise free 100% and sounds fantastic .
    10.5 lcd touchscreen ,shuttle XPC,AMD +2100, 512 DDR, 120 GB drive ,slot dvd,Dashwerks shutdown controller,GPS, XM Direct
    qaz
    qaz is offline
    Oct 2004
    as of a month ago i put everything in in a weekend. so far its working great. ive done a lot of stuff to my truck and car (new engine, 2 lifts, starter...) so i know how things usually go. But this has probably been one of the smoothest mods ive done. i can say ive had almost no problems. im using an inverter, xenarc 700sv touchscreen, western digital 13.6gb p4 1.5 w/ some full size mobo, gps, and a keyboard in the visor; all running with frodoplayer (thanks frodo). this was a glove box install so its not like i had a lot of room to work with either. take that for what its worth though and good luck.
    Maximum Bitrate cadence117's Avatar
    Feb 2004
    Charlotte, NC
    5 months straight with nothing but maybe 2 or 3 faulty resume-from-hibernations
    mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
    Total = $746....Carputer = Priceless
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    P4 2.2, Asus motherboard, Inverter, Used lilliput,
    1 month, no problems at all, except I keep wanting to add more things
    肚子笑痛了
    S60 Install
    Mine worked from install, after I cracked a few ground loop issues it was fine.
    I have noticed that the people who have the most problems are the people who scrimp and take financial shortcuts. Buy a xenarc rather than a lilliput, get a proper Opus etc.
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    It's worth it, if you take the time, take the money, and do it right, it'll be rewarding. I 'skimped' and bought a lilliput, it works great. I only have one issue and that's when my music starts getting real loud, it skips, and my carputer restarts if this continues for too long, i'm pretty sure it's skipping because the amp is maybe turning on/off, but it's most likely my battery, which is pretty old.
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
    Nov 2004
    Kildare Ireland
    so far I have
    OPUS 90W
    via M10000 512MB RAM 80GB HDD in a really tight box!!
    Hauppage USB2 WinTV/FM
    IrMan
    GamePort Based Steering wheel stalk conroller
    gonna get...
    USB WIFI
    USB BT
    USB GPS
    4 Channel PowerAmp
    ...IN DASH Xenarc
    cannot wait...
    Meant to ask u chaps -I'm completely paranoid about frying my boards with static everytime I accidently touch a board i keep thinkin its gonna be f**ked. what are the chances ? is it like high risk or would you have to be pretty unluck?
    ps. rock on da frodo player!!
  1. Replies: 45
    Last Post: 12-05-2007, 02:07 AM
  2. Replies: 4
    Last Post: 11-13-2004, 06:00 PM
  3. Carputer install
    By H3nrY in forum Newbie
    Last Post: 07-25-2004, 10:45 AM
  4. Need help with install of carputer using a laptop...
    By slimcubby in forum General Hardware Discussion
    Last Post: 04-27-2004, 01:55 PM
  5. Replies: 2
    Last Post: 04-26-2004, 07:29 AM
