Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 46
Thread: BMW 318is CarPC
  1. #11
    Constant Bitrate phatbenny's Avatar
    Jul 2004
    Birmingham/London UK
    Thanks mate, will do, but not going to start the install proper for a couple of months.
    Hardware:- VIA EPIA MII 12000 LVDS 1.2Ghz : £137.95 + 512Mb PC2100 DDR Memory : £49.34 + Opus 150w Shuttle PSU: £128 + 7” Lilliput 629 Touchscreen: £173.90 + 2.5” 40Gb 5200rpm Laptop Drive + Slotload Laptop CD-RW/DVD-ROM + Hauppage WinTV-PCI-FM : £53.95
  2. #12
    Maximum Bitrate Skipjacks's Avatar
    Dec 2004
    Baltimore, Maryland
    Just so you know, I just wired up my lilliput in that double din spot tonight. It looks great. Only trouble I'm having is finding a way to make is securely mounted in that spot. But I've only been at it for an hour....so I'm not running out of idaes yet by any means.
    Just one thing, if you do get the lilliput, get the black one. It goes to well with the black dash.
  3. #13
    Constant Bitrate naveedh's Avatar
    Oct 2004
    I think if you have it lower you will see it better as much light wont reflect of it as if it were in the double din.
  4. #14
    Dec 2004
    Baltimore, Maryland
    Quote Originally Posted by naveedh
    I've been told that exactly from people who've installed the screen down low.
  5. #15
    Oct 2004
    well for me it was experiance So it is true.
  6. #16
    Jul 2004
    New Bios Logo
    I've finally changed the full screen bios logo to a BMW one. I had a few problems creating the image in Photo Shop as it left a white border after flashing. I got round this by creating the tif in Paint Shop Pro. Alastair Richards was really helpful. For full instructions check CdRsKull's thread. The logo looks like this and here is a copy of the I0A00135 bios for the Epia MII boards. It worked for me so I assume it will work for you. However take care flashing your bios and only do it if you are confident or rich. I'm not responsible for you using this bios file.
    Glad this is over with, it's taken me ages to do such a simple job.
    A little bit of advice, create a bios recovery disk on a floppy before you start. It needs to be formatted with system files including the flash utility, safe bios, and an auotexec.bat file with a command line to autorun the flash utility with all the ocrrect tags, to force run it and restart afterwards. I messed up a flash and lost the video output at the same time. I had to recover blind.
    Now I've got to reskin windows properly.
  7. #17
    Jul 2004
    I invested in a Hauppage WinTV-PCI-FM card this week. I know it's a bit early in the install but I wanted TV in my room for a while. I paid £53.95 from PC World for it, because I wanted it in a hurry. Good news, the radio works fine. Bad news, TV is non-existant with a portable aerial in my room. I have the radio working with fp but not with radiator. DOn't know how I've done it. The only bit of the radio not to work in fp is the seek function. I need to trawl the forums for a solution on that.
  8. #18
    Jul 2004
    Ntoskrnl
    I've also given up on editing the windows boot screens, due to the pallete problems it is impossible to create a good looking image, so at most I might just turn the screen black.
  9. #19
    Jun 2004
    AZ
    Has anyone figured out an easy way to edit the windows boot screen to add the bmw logo?
  10. #20
    Dec 2004
    Baltimore, Maryland
    Use a boot screen program. It'll do all the work for you. You just supply he pictures.
  1. 2001 BMW E39 - fully integrated Carputer
    By tsingsu in forum Show off your project
    Last Post: 05-03-2006, 05:51 PM
  2. CarPC for my new 106 Rallye
    By fireball106 in forum General Hardware Discussion
    Last Post: 04-04-2006, 05:19 PM
  3. 03 BMW 330i Dinan S3 Project
    By fattytl in forum Show off your project
    Last Post: 09-27-2005, 11:24 PM
  4. CarPC PictureViewer! works with ALL engine
    By dragonBTV in forum Software & Software Development
    Last Post: 02-02-2005, 09:56 PM
  5. Loud noice when turning on CarPC
    By Andreas106rally in forum Car Audio
    Last Post: 11-03-2004, 12:27 PM
