Same size and ohm rating, and you shouldn't have a problem. Try to get as close to the orginal specs as possible.
www.partsexpress.com is a good place to start for the drivers.
I think the driver on my bazooka 10" model T102A70 crapped out on me... instead of getting a replacement from bazooka can I add another woofer with similar specs?
here are the specs I got from bazzoka:
woofer size: 10"
Voice Coil Size: 1.5" high power /high temp
magnet size: 28oz
frequency 39-1000 Hz
efficiency 104dB
power handling 6-200W/channel
T102 dimensions: 20.75" X 10.3" x 12.2"
impendance 4ohms
I have an amplified version I think it's 70W RMS so I don't need anything expensive...
any suggestions?
04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
Fast car, fast PC. ;)
http://www.arcdesigns.net/carpc/
My TL CarPC ver2
FSR Flash Skin w/ moving weather maps
yes you can replace it with another brand, the sound may or not be the same as before (in either a good or bad way depending on how far off u go from the original specs)...
what you do is find the cubic inches of the box (simple math) and then search for a driver that was designed for boxes of the same cubic inches (or very close) and you will be back to terrorizing the neighbors with your loud music in no time![]()
