Results 11 to 20 of 21
Thread: Can someone double check my Opus wiring please
  1. #11
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Do you need to reinstate the "boot on power resume" or summit? Or does the opus send the on signal to the board?
  2. #12
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Bailey
    No, I reset the settings to Default. My mobo was purchased used and I didn't want any of the previous owner's settings interfering. Looking back on it, it may not have been such a good decision.
    I remember my family bought a new sony TV and I decided to play around with the settings. When I pressed the rest button it wouldn't work anymore. Turned out to be a faulty TV
  3. #13
    Variable Bitrate Bailey's Avatar
    Nov 2004
    NYC
    Quote Originally Posted by Scouse Monkey
    Please speak slower
  4. #14
    Mar 2004
    Bristol
    Please speak slower
    DOES THE BIOS HAVE A RESUME ON POWER RESTORE SETTING?
    ie when you put power to the PC it immediately boots up. most dektop mobos have this in the bios and Most people building a PC should know what i mean by this feature.
    You see some PSUs - especialy the old mas/sproggy rely on this feature to get your PC to boot as they did not have the capability to send a start pulse.
    As i have never used an Opus before so i don't know if you have to enable the start pulse somehow so maybe you had the resume setting active in the bios before which is why it worked.
    PS phrases like "please speak slower" are a bit rude - especially when people are taking time to help you!
  5. #15
    Nov 2004
    NYC
    Hey man take it easy, no rudeness intended. I even included a smiley face. No need for any of that stuff.
    I was confused because I thought you understood I cannot boot the computer, not even to POST. The only thing that happens is the keyboard LEDs light up for a second, then the Opus throws the 2 flash code. The CPU fan doesn't even spin up for a second.
    I have reset the CMOS via the reset jumper. I disconnected all IDE cables. I checked my ground, and my battery's voltage is well over 15v. The polarity of my PWR_ON switch is fine. My fuse is in tact. I pulled the fuse for a few minutes while disconnecting the power.
    I'm about to plug in a spare ATX psu... stand by for update.
  6. #16
    Nov 2004
    NYC
    I plugged in my only spare ATX psu that was working when it was put away. I plugged in the ATX connector, and that's it. Switched the PSU "on" and keyboard LEDs light up. Short the PWR_ON+ and PWR_ON- and I get nothing. Did I try to start it up correctly?
  7. #17
    Mar 2004
    Bristol
    Have you tried reconnecting a normal switch to the mobo and trying this to boot up?
    Oh and is the cmos jumper back in the right place?
    If the keyboard lights up for a second then the standby rail seems to be working.
    what does the opus 2 flash code mean?
  8. #18
    Mar 2004
    Bristol
    sounds like its dead!
    last resort after double checking everything would be forcing the PSU to start by shorting out the correct pins in the ATX block (middle green to a black i think but i would check that)
  9. #19
    Nov 2004
    NYC
    I don't have any normal switches to try, so I just short the two wires out.
    If it's dead... I'll kick myself in the head a few times.. but I hope I can figure out how it got dead.
  10. #20
    Nov 2004
    NYC
    Okay folks, here's a lesson from Uncle Bailey. Do NOT let this happen to you.
    Do not work 11 hour shift, come home all excited to see your final carputer items sitting at the doorway, and go right at it. First you must get washed up, eat something, have a drink, go smoke a cig if you're into that, rest up and relax. THEN start very slowly connecting everything. If something doesn't work, go smoke another cig, THINK and calm down.
    I was shorting the wrong pins. No excuse for it. I'm very sorry everybody. Another lesson learned.
    I guess, somewhere in the back of my mind, I know these carputer parts are very delicate... I'm just waiting for something to blow up. I'm not gonna think that way for another second. I just gotta have patience.
  1. Replies: 35
    Last Post: 05-11-2005, 04:49 PM
  2. Wiring Opus to ignition and interior light
    By Maverick in forum Power Supplies
    Last Post: 01-12-2005, 05:16 PM
  3. Replies: 4
    Last Post: 08-11-2004, 07:07 PM
  4. OPUS 90W wiring!! PLEASE HELP!
    By GMCVOY in forum Power Supplies
    Last Post: 08-05-2004, 10:55 AM
  5. Specific wiring schematic 4 Optrex DMC40457?
    By sooty in forum LCD/Display
    Last Post: 07-17-2001, 03:11 AM
