Results 1 to 5 of 5
Thread: Wire connectors
    FLAC migel628's Avatar
    Mar 2004
    New Windsor, NY
    Wire connectors
    OK, I'm not sure how to phrase this, but I'm looking for connectors to go on the motherboard for the Power LED, Power Sw, HDD LED, Reset Sw. I have to extend the ones I have and the case I'm using hase them in a block.
    If someone knows the correct names & what I'm looking for, then please point me in the right direction...
    "I'm a dick!"
    "I must seek knowledge and it's bastard son truth" - The State
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    I think you're the third person to ask that in a week....
    And you're not even a newbie!
    Run to ratshack and pick up some new led's, momentary switches, and some cheap speaker wire. Cut the existing wires and re-use the header connectors.
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
    Mar 2004
    I found mine at our Microcenter Warehouse (national computer store). They have a pak that has HD LED, Power LED, Power switch, Reset Switch cables with the motherboard connectors. I did not want to use my current wires from my case, so this is what i did
    Mar 2004
    New Windsor, NY
    Quote Originally Posted by PatO
    Yea, I found that I had a leftover NetVista case, but the header connector is in a block. So, I need to cut the wires, extend them to reach the desired location, and find something to replace the header connector. I just didn't know the proper name of what I was looking for, so that I could look for it...
    "I'm a dick!"
    Mar 2004
    New Windsor, NY
    Found what I was looking for:
    http://www.frontx.com/order_c.html
    HEADER CONNECTOR 1 X 1
    "I'm a dick!"
  1. In search of an ignition wire
    By witten in forum Power Supplies
    Last Post: 07-27-2006, 02:29 AM
  2. Where to you buy blade wire connectors for your power switch?
    By mykolJay in forum General Hardware Discussion
    Last Post: 07-27-2004, 06:29 PM
  3. Replies: 37
    Last Post: 05-17-2004, 08:01 PM
  4. Replies: 11
    Last Post: 03-09-2004, 10:59 AM
  5. ignition wire for opus psu
    By liquid_smoke in forum Power Supplies
    Last Post: 09-09-2003, 11:58 PM
