Results 1 to 10 of 18
Thread: Startup is too fast!!!
    Maximum Bitrate EBFoxbat's Avatar
    Jun 2004
    Massachusetts
    I have a few programs that run in my tray on startup. Nothing to intensive just so programs I like to have run. One of them requires a live internet connection which I have with cable. However, the program tries to connect to the internet apparently before my computer has gotten its IP from my router. Thus I get DNS errors and stuff.
    Is there a way to delay programs that run on startup? I only need it to delay 2 or 3 seconds. Any ideas? Would moving it into the startup folder do any good (right now it's just enable in msconfig)?
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
    Jun 2004
    Massachusetts
    BTW google only offers programs that do this... I was hoping to do it with a registry hack or something.
    ,./(0)3
    Dec 2004
    delete its registry startup entry and put it in the start menu starup folder... that may work
    Jun 2004
    Massachusetts
    Quote Originally Posted by thecommiser
    Didn't work.
    ,./(0)3
    Jan 2004
    Jersey/NY
    There's a way to run a batch file (*.bat), and in that batch file, delay for a little bit, and then run a program.
    Sorry I don't remember the commands off of the top of my head, but it's not very hard.
    Constant Bitrate Ill1's Avatar
    Jun 2004
    Woodbridge, VA
    Use AutoHotkey, www.autohotkey.com , to create an exe that waits for a said amount of time and then runs whatever program you want. Off the top of my head the script would be something of this nature:
    Sleep, 3000 ;wait 3 second
    Run, FULL_PATH_TO_PROGRAM_YOU_WANT_TO_RUN
    Compile the script and place it in your startup folder. This probably isn't what you were looking for, but it is a solution.
    ________________
    ______ILL.1______
    Jun 2004
    Massachusetts
    I made a batch file and tossed that in the startup folder
    Code:
    @ECHO OFF
    ECHO Delaying gNotify start up. Please wait.
    SLEEP 1
    CLS
    ECHO Delaying gNotify start up. Please wait..
    SLEEP 1
    CLS
    ECHO Delaying gNotify start up. Please wait...
    SLEEP 1
    CLS
    SLEEP 1
    CLS
    START "gNotify" c:\gmail\gnotify.exe
    I wish there was a way to trick the file into thinking that I pressed the enter key.
    ,./(0)3
    Jun 2004
    Massachusetts
    The SLEEP command won't work unless you download sleep.exe from microsoft.
    ,./(0)3
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    why do you need to press the enter key?
    肚子笑痛了
    S60 Install
    May 2003
    Miami, FL
    Nevermind, I see your problem, if you make a shortcut to the gmail.exe file and keep in the same folder as the exe and change your batch file to the below it should make the dos window dissapear
    Code:
    @ECHO OFF
    SLEEP 1
    CLS
    SLEEP 1
    CLS
    SLEEP 1
    CLS
    SLEEP 1
    CLS
    c:\gmail\gnotify.lnk
    肚子笑痛了
    S60 Install
  1. Music track fast forward bug
    By Bootbox in forum CF Bug Reports
    Last Post: 12-06-2004, 10:22 AM
  2. Laptop Startup Solution - Opinion
    By Fox_Mulder in forum General Hardware Discussion
    Last Post: 11-20-2004, 04:33 AM
  3. Replies: 3
    Last Post: 09-28-2004, 01:13 AM
  4. usb fast enough?
    By ShinkunoNamida in forum General Hardware Discussion
    Last Post: 06-02-2002, 01:52 AM
  5. Fast and the Furious (Arby please read)
    By hornet in forum Off Topic
    Last Post: 03-17-2002, 03:26 PM
