Results 1 to 10 of 10
Thread: My Documents screen always opens
    n00b 4 life mp3oplecarrier's Avatar
    Dec 2003
    Chatham, UK
    This has been happening for a while on my desktop (since installing SP2) and I can't find any relevant answers anywhere else so I thought I'd try you clever sods..
    Everytime I log on to my user account, a window opens up in the middle of the screen showing the contents of the 'my docs' folder, it doesn't matter if I close it and restart or minimise it first it always comes up the same size and position in the middle of the screen. the same thing happens on all the other users with their own 'my docs' folders
    Any ideas?
    Is someone ****ing around with my PC?
    Cheers
    Steve
    ....Yes, I know it has a stupid name, those crazy Japanese!
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    download hijackthis, and see whats starting up on your computer. i doubt its anyone messing with you.
    PC Components:
    My work log
    Dec 2003
    Chatham, UK
    I know, I'm just paranoid and hate it when I can';t work something out!
    Cheers I'll try that tomorrow when I'm more awake..
    Maximum Bitrate dodgetimes2's Avatar
    MI
    Or run regedit and check all the items in the following key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Run
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by dodgetimes2
    For windows XP, this alone will not work.
    As suggested, download and run hijackthis, and remove suspicious items. Also get Spybot S&D and Ad-Aware SE. Update and run those as well. Hope this helps eh?
    Tidder
    Try RevFE
    MI
    HiJack This is basically just a frontend for editing the HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Run key. It also shows you what extra buttons have been added to IE etc. I was just stating what the easy fix would be for getting rid of the My Docs folder showing on startup. Now if you really want to protect your PC, run AVG Free, Ad-Aware SE, and ZoneAlarm, and put your PC's behind a router and firewall.
    Sep 2003
    New Mexico, USA
    No man, you're way off. Hijackthis also takes care of the HKEY_CURRENT_USER run key, and BHO's as well. Also, don't forget about dumb programs that puts crap in the runonce key, and what about SERVICES man?! RunServices key also has junk in it as well, depending on which version of windows. And it also shows what's in the startup folder on the start menu as well, current user and all users. Something wrong in there could also be causing the My docs to show up. I'm not saying you're wrong, just clarifing, to help the unknowing.
    Tidder
    Try RevFE
    Elsewhere
    It could be as simple as a shortcut to the My Documents folder in your startup group.
    How about the Wiki?
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    Quote Originally Posted by DarquePervert
    That's what I was thinking. I shortcut in C:\Documents and Settings\All Users\Start Menu\Programs\Startup would open it in all user accounts.
    ATVMS.com
    Dec 2003
    Chatham, UK
    Sorted!
    Thanks for your help guys!
    Hijack this solved the problem without any grief
    Steve
  1. Replies: 4
    Last Post: 01-29-2005, 07:35 PM
  2. Replies: 5
    Last Post: 04-30-2004, 12:25 PM
  3. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
  4. NEC Versa M/75 Laptop TFT screen w/touch
    By Macgyver777 in forum LCD/Display
    Last Post: 03-24-2002, 03:14 AM
  5. Laptop/LCD screen hookup...
    By UrbanTacticz in forum LCD/Display
    Last Post: 11-28-2001, 06:49 PM
