Results 1 to 6 of 6
Thread: Moving your headunits face.
    Oct 2000
    Vancouver, Canada
    Question Moving your headunits face.
    I'm not sure what area to put this in so I thought General will do.
    Have any of you guys moved your faceplate off the cd receiver headunit and mounted it permenately eslewhere? Then just run cabling to the headunit? I can't remember but isn't there only (at most) around 10 pins?
    Just a thought.. then you could put the unit under the seat and clear up some room for indash things.
    95 Honda Civic DX Coupe - In Progress
    mp3civic site
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    Post
    if you are going to do that, then why have a headunit at all? why not buy an FM-tuner and hook up the puter to an amp?
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    Total spent on wedding so far: $3885.79
    Thanks to everyone for your support.
    I'M DEBT FREE!!
    Oct 2000
    Vancouver, Canada
    Post
    because I don't have amps.
    mp3civic site
    Aug 2000
    Post
    it can be done, it is not too hard (also not the easiest thing) I have seen it done a few times
    there are plenty of places that sell the wire u will need, after that it is a matter of time and patience...
    Oct 2000
    Vancouver, Canada
    Post
    Kain101: Do I need special wiring? Could I just run some ribbon cable after I find a connector that will work on both ends? It's a Kenwood deck and there are just 10 pins 5 on top and bottom I believe.
    mp3civic site
    Aug 2000
    Post
    you can run ribbon wire... now all the ones that i have seen with the faceplate in one area and the main body in another had the wires directly soldered but, if you can find a connector 1.) more power to you, and 2.) let me know where u found it...
    good luck, and remember to post plenty of pictures
  1. Just had a great idea for using a detachable cd players face
    By Gemini in forum General Hardware Discussion
    Last Post: 05-13-2004, 01:15 PM
  2. Headunits with red lights?
    By none in forum General MP3Car Discussion
    Last Post: 03-28-2004, 07:32 AM
  3. Is it possible to connect to headunits?
    By BigGuns in forum General MP3Car Discussion
    Last Post: 02-17-2004, 11:44 AM
  4. Rugged pc XP and no moving parts
    By babas151 in forum General Hardware Discussion
    Last Post: 09-23-2003, 06:24 PM
  5. Detachable face as remote control
    By cruzc_99 in forum Off Topic
    Last Post: 10-11-2002, 09:02 PM
