Results 1 to 4 of 4
Thread: u gunna hate me...
    Constant Bitrate grum's Avatar
    Feb 2005
    australia, melbourne
    u gunna hate me...
    Sorry im starting a forum and im pretty sure i could find out what i need if i searched hard enough. But its kinda specific:
    ok, so i have a acer travelmate 520iT laptop, 2X25 watt (RMS) amp, pioneer headunit (with NO aux in), ****loads of all types of cabling, and a whole bunch of questions:
    The pioneer is directly powering my 6" in my door panels and the rear rca is going to the amp.
    firstly
    i read about a fm modulator direct cable connection... do i need a signal filter if i get one of these? cos i dont want **** sound quality and more boxes hanging off all the cabling.
    what other ways could i connect my stereo to my computer.
    if i connect my laptop to my amplifier i only get the rear speakers, do you guys know of any passive rca switches with volume control, so i can change to the laptop and quickly change volume instead of changing in windows or going into the boot of my car.
    also how hot do the inverters get. because looks like im going to be using an inverter to power my computer, which already has a chunky transformer on it. = a lot of heat.
    can i mount the laptop directly to the floor or should i make some shock dampening suspension?
    how would i auto start the laptop, i tried the wake on lan thing, but that only works for sleep mode and not hibernate, and i would drain the laptop batts if i did it this way. shutting down the laptop isnt a prob..
    i also ripped the laptop apart to find out if i could wire up a power s/w or a vol control, without any success - got any ideas?
    And one last thing, would my amp still be able to run effectively if i run a 300W inverter to my laptop? (my amp is only a 2X25 watt).
    (this is also asuming im using the same power cable from the battery for both the amp and the inverter.) its a think guage, but id doubt the laptop would use more than 100W right?
    and dont say:
    cos i tried
    CarPC Status:
    Hardware: 100%
    Software: 100%
    Case Install: 100%
    Dash Install: 100%
    Car Install: 100%
    crap factor: 100%
    new carpc finished, thinking of way to mount HDD
    and not installed yet.
    Feb 2005
    ok audio is fixed
    Pioneer CDRB10 !!!!!! ok i have the input worked out... - no fm modulators or dodgy installs yayayay!!!
    CarPC Status:
    Hardware: 100%
    Software: 100%
    Case Install: 100%
    Dash Install: 100%
    Car Install: 100%
    crap factor: 100%
    FLAC NiN^_^NiN's Avatar
    Aug 2004
    Australia, Melbourne
    Quote Originally Posted by grum
    firstly
    and dont say:
    cos i tried
    Grum get a Car Laptop adapter to power the actual laptop it's basiclly the same brick you use to power your laptop inside but it connects to the cig socket.
    Also i would see if I could find a Docking station for the laptop so you can power it on and off and you can slot the laptop out when you want and slot it back in
    And you won't have to reconnect the usb plugs etc if you get a docking station.
    I gather your gonna make the laptop shutdown when it runs on it's own battery?
    Alot of people mount their laptops under their seats and use velcro strips to hold it there and they haven't had any problems at all
    For Volume control you can actually make a small knob which connects between the laptop and the headunit to control it
    Cause your in ringwood you chould check out Jaycar they have the laptop adapter etc
    www.jaycar.com.au you can see what they have online so you have an idea price wise
    If your got any more questions just ask
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
    Feb 2005
    happy!
    ok forget it, all is fixed. now all i need is for my parts to arrive.
    :P
    CarPC Status:
    Hardware: 100%
    Software: 100%
    Case Install: 100%
    Dash Install: 100%
    Car Install: 100%
    crap factor: 100%
  1. I Hate Paypal
    By NightHunter in forum General MP3Car Discussion
    Last Post: 07-15-2008, 02:56 PM
  2. Hate Bob Saget...please
    By cadence117 in forum Off Topic
    Last Post: 10-02-2006, 01:56 AM
  3. I hate newbie threads ......but
    By emdawgz1 in forum Newbie
    Last Post: 02-03-2005, 03:11 PM
  4. Neopolitan Ice Cream - LIKE IT OR HATE IT???
    By Scouse Monkey in forum Off Topic
    Last Post: 11-28-2004, 02:43 PM
  5. I hate my life
    By lstrunk in forum Off Topic
    Last Post: 10-17-2003, 10:08 AM
