Results 1 to 10 of 15
Thread: Heat!!!!!!!!
    Registered User
    Apr 2000
    New Concord, OH, USA
    Unhappy Heat!!!!!!!!
    Been running a bookpc since Nov. with no problems. The past couple days it has been in the 90's and I'm seeing a problem I think is heat related. The player boots up and plays for about 10 or 15 minutes and then locks up. If I shutdown and wait a little while it will bootup and play again. Anyone running a bookpc seeing the same problem. I have a 533 Celery in it. Would dropping back to my 233 cut down on the heat? I could put another fan in but it would be a tight fit if I could get it in at all.
    Feb 2000
    Rockford, IL (home), Southern IL (college)
    Post
    Im kind of running into heat problems also. Heres what ive done to combat future problems.
    1.) added an extra fan
    2.) improved circulation
    3.) bought a winshield shade from Pep Boys (this is supposed to reduce overall car temp up to 50 deg., and i almost believe it!)
    4.) Cracked the window when possible.
    5.) Park in the shade whenever possible
    Other things that might help.
    - Run cpu idle software (i cant think of any off the top of my head)
    - Get some thermal paste for the cpu (Arctic Siver is the best stuff, but expensive...this will help provide a better contact between the cpu and fan which improves cooling)
    Im sure theres some more things you can think of, and im sure the rest of the board can help also.
    2004 F-150
    Shuttle XPC, 80gig HD, Wireless Internet, DVD
    "How piMP3d is your ride??"
    Aug 1999
    Upper Marlboro, MD 20772
    Cool
    Yep, i had the same problem the otherday and i knew what it was....HEAT!!!! So i turned on the extra fan i added in January. So far box is working fine. I will wait til sunday to c if this solves my problem. Nice thing is that i can cut this fan off durring winter or what not....
    abcd-1
    Registered User
    Apr 2000
    Post
    I'll have to bring the box in and see if I can get another fan to fit. Maybe add some holes for better air flow. Not many choices with the bookpc case though. Heat buildup is not a problem, most of the time the upper doors are off when parked unless it's raining and it is under the seat so it should be shaded all the time. I guess I had to give something for the small size (which means small fans)
    Jun 2001
    Sebastopol, CA
    Post
    I have a book PC as well, and I have noticed that the fan output is a bit warm lately (80s to high 90s here). It hasn't crashed or locked though, and not warm enough to be a concern. It has a custom power supply as well. You could change out the PS fan for something with more CFM. Or add some more air inlet holes, there aren't many at all in my case.
    Ryan
    Mar 2001
    Perth, Australia
    Post
    1. get a fan trace out side and mark holes for drilling.
    2. cut whole and drill outer holes.
    3. place fan on inside of case screw in with self tappin screws.
    4. also get a grill to go over top to protect fingers and other foriegn objects getting cut up.
    5. wire fan up to spot on mother board 5v or get an adapter to use hdd power use still get to use it for hdd as well.
    GK
    GK is offline
    Jan 2002
    Post
    Originally posted by RaZor:
    <STRONG>- Run cpu idle software (i cant think of any off the top of my head)</STRONG>
    Great idea! Did you notice a difference?
    3rdgen.org - Real Cars, Real People, Real Fast!
    Oct 2001
    NYC
    Post
    get those ventshades ofr your windows...
    also, try underclocking the processor...
    or...watercooling!!
    Feb 2000
    Post
    i havent tried it on my pc yet, but ive heard of people who have pcs in their homes who use it and it decreases temps by 2-8 degrees.
    2004 F-150
    Mar 2001
    Cincinnati, OH USA
    Post
    Originally posted by Alives:
    <STRONG>get those ventshades ofr your windows...
    or...watercooling!!</STRONG>
    LOL Watercooling for a car player?? Most people try to keep the size of the case down to a minimum.
    http://www.mp3car.com/usersites/Maveric/ M.A.V.I.C. System
    Asus MB, PII 266, 192 MB Ram, 6.8" LCD, 6 Disk CD-ROM, 21 Gig HD, All-in-Wonder Video w/ TV Tuner, Irman, Windows ME, Winamp, Cobra III -- All in a custom acrylic case.
    http://www.mp3car.com/usersites/listings/ MP3car Listings - Please add to it! :)
  1. Heat problems??
    By TheKurbster in forum Software & Software Development
    Last Post: 05-22-2004, 01:19 PM
  2. To heat sink or not to heat sink ...
    By jnusaira in forum Newbie
    Last Post: 02-18-2004, 10:46 AM
  3. CPU Heat question: Which one would generate less heat?
    By kiztope in forum General Hardware Discussion
    Last Post: 02-12-2004, 03:14 AM
  4. Summer heat MP3Car trial complete
    By Moose in forum General Hardware Discussion
    Last Post: 07-10-2003, 01:25 AM
  5. COOLING THE CARPUTER
    By moahdib in forum General Hardware Discussion
    Last Post: 07-04-2002, 09:18 AM
