Results 1 to 10 of 13
Thread: Exhaust Help
    Maximum Bitrate EBFoxbat's Avatar
    Jun 2004
    Massachusetts
    Exhaust Help
    I don't know much about exhaust so I'm throwing this out to the wealth of car knowledge here.
    I want to add a switchable exhaust cutout before my catalytic converter. I want to run a pipe from the cut out down the length of my truck to merge with the tip. That way there would be no outward appearance of anyhting being different other than a thunderous roar when I flip the switch,
    If the cutout goes before the catalytica converter, will the sensor that controls fuel flow (that's in the exhaust isn't it) trip an engine warning light? Is it bad for the engine... I mean will it end up flooding itself with gas or is it just a light?
    Because running with the cutout open is illegal on-raod, I won't be doing it much. Mostly just for show, maybe a flame system later. Would the check engine light reset itself once I closed the cutoff and the exhaust ran through the stock cat and muff?
    Please offer input here. Google didn't help me much with a "exhaust cutout" search. Thanks.
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
    Registered User Dudes99's Avatar
    Dec 2004
    Norfolk, Va
    Good question. No way to know unless you test it. If you just get under the car and disconnect it the ECU should put the car into a cold start situation (it will run rich) 0 volts sensed)shouldn't hurt anything though. Being a GM product it will probably throw a code though..........
    Google'd exhaust oxygen sensor bypass
    Maximum Bitrate dodgetimes2's Avatar
    MI
    My Ram has no exhaust and I get a Check Engine every once in a while. To get rid of it I just disconnect the truck's computer or the battery for a few minutes.
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
    Jun 2004
    Massachusetts
    Running rich will just kill my mileage right, not my engine?
    ,./(0)3
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Quote Originally Posted by EBFoxbat
    I think so. it will also kill the cat if you are running one but as youa re doing the bypass that won't matter. A rich engine will run cooler (one reason, apart fromt he obvious waste of fuel) why it will not be as efficent as the hotter you can run any engine the more energy you are extracting from the fuel.
    I think the new Ferrari has some kind of exahsut bypass system so when you are really gunning it it misses out part of the exhaust to give more power but when driving in town gently the extra section is used tokeep it quiet.
    I doubt you will be able to find one of those mechanisms on ebay just yet though!
    Jun 2004
    Massachusetts
    I just got out from a while under my truck.
    The O2 (i think its O2) sensor is right after the cat. There's no room to put a cutout in before the cat, so I'm going to do it after. That will just bypass my muffler. The cutoff exhaust and stock exhaust will meet up before the tip so it will only look like one exhaust.
    Anyone know what a straight-5 roar is like w/o a muffler? I'm the only one I know with the new 3.5L inline 5-cylinder engine. I decided it was foolish to have dual exhaust (I wanted split rear) with out a V-engine... something about having only one header and making a fake dual exhaust makes me feel silly.
    Hmm... I may do this on my own... known need to pay a shop what I can screw up on my own...
    ,./(0)3
    Dec 2004
    Miami, FL
    I'm not claiming to be an expert in this, but if you start changing the way your exhaust works, your ECU is going to get all confused. Any major exhaust changes usually require an ECU reflash to learn how to efficiently utilize the new system. If you're changing on the fly, your ECU wont have a chance to learn, and you may end up actually losing performance when you switch to bypass the cat.
    Again, I may be very wrong, but until you discuss this with someone who knows more about mods, I would be hesitant to start cutting parts.
    A car without turbo is a car with perpetual lag.
    My Ride
    My New Page
    Newbie red green's Avatar
    Columbus AFB, MS
    ...Anyone know what a straight-5 roar is like w/o a muffler?...
    First, let me say that you might want to check with an inspection station first, as I'm pretty sure Taxachusetts has a couple of rules regarding modification of exhaust systems.
    I'd say the sound has less to do with the cylinder configuration and a lot more to do with cam profile and displacement, so you might want to ask other folks who have 3.5L engines. In fact, a good comparison might be the old 4.0L Jeep inline 6. I'm sure there are several off-roaders out there (at Off-Road.com) with headers and no mufflers.
    Also, I question your need for the cutout. You might be much better off with a carefully planned system that includes a high-flow cat and an appropriate muffler for your setup. In fact, you might want to visit a GMC forum like GM-Trucks to get more expert advice on your particular setup.
    HTH
    Mike
    1998 Volvo V70 R AWD
    2.3L Turbo @ 17psi, 20% Tint
    SP-13000, 7" Lilli, Opus 120, 120GB SATA, Holux GR-213, Headrest LCDs
    Constant Bitrate RPI Geek's Avatar
    Oct 2004
    Schenectady, NY
    Yes, but it can also foul your spark plugs. IIRC, Running rich leaves excess carbon in the exhaust gases, which will end up all over your cylinders, valves, and spark plugs - fouling them.
    Old plans out the window because of an accident .
    Have: M1-ATX, EPIA M10000, 256MB, 60GB 2.5", slim slot load DVD
    Need: Time, HU integration, ideas for Lilli
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    I did that in my old jeep and can you SAY LOUD! It sounded a bit like a big *** diesel truck. so much more power.
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
  1. Cooling Suggestions for custom box~!
    By bulgogi777 in forum General MP3Car Discussion
    Last Post: 04-01-2005, 12:05 PM
  2. Sound - record/playback chips
    By SuperMatty in forum Off Topic
    Last Post: 03-29-2005, 06:57 PM
  3. Exhaust System Advice
    By EBFoxbat in forum General MP3Car Discussion
    Last Post: 12-09-2004, 06:25 AM
  4. need some serious help: blown headgasket
    By bgoodman in forum Off Topic
    Last Post: 12-08-2002, 06:35 PM
  5. Flaming Mini
    By Rob in forum Off Topic
    Last Post: 06-08-2002, 09:31 AM
