Results 1 to 8 of 8
Thread: Finally everything works....almost
    Jun 2001
    Washington State
    Post Finally everything works....almost
    I am now done with my install, although I need to hide some wores and do some cosmetic work. Anyway I have one last problem.
    When I play my sound it sounds great, except for a constant humming in the background. It is there with or without the car running. And I don't even have to be playing winamp. If the comp is just on and I turn up the volume I can hear the noise. It is not unbearable, but it is always there in the background, quite when the sound is low, but it seems to rise as the volume increases.
    Thanks in advance for your advice, and I have done some searching on the subject but couldn't decide if others' problems were the same as my own.
    Mar 2001
    Cincinnati, OH USA
    Post
    Sounds like ground loop. Is your case grounded to the chassis? Are you power and audio wires running together side-by-side? If they are it can cause noise. Try doing that, if it doesn't help you can get a ground loop isolator from Radio Shack
    http://www.mp3car.com/usersites/Maveric/ M.A.V.I.C. System
    Asus MB, PII 266, 192 MB Ram, 6.8" LCD, 6 Disk CD-ROM, 21 Gig HD, All-in-Wonder Video w/ TV Tuner, Irman, Windows ME, Winamp, Cobra III -- All in a custom acrylic case.
    http://www.mp3car.com/usersites/listings/ MP3car Listings - Please add to it! :)
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    Lightbulb
    Sounds either like a bad ground or your wires are running by a source where they are picking up interference.
    Did you run your audio cables on the opposite side of your power cables?
    Are they good sheilded rca wires your running for audio?
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
    Jan 2002
    Long Island, NY
    Cool
    hey, you stole the words right out of my mouth.
    Jinx, you owe me a beer!
    Jun 2001
    Washington State
    Post
    Thanks for the suggestions guys. But what do you mean is the case grounded? What would I ground? Right now It sits in my trunk, and the audio runs up the center of my car, while the power lines are run along the doors.
    Maximum Bitrate PoBoy's Avatar
    Jun 2001
    St. Louis-MO
    Post
    Grounding:
    Take a wire (any guage will do)...run it from a screw on the computer to a metal part on your car. MAKE SURE THERE IS NOT PAINT COVERING THE TWO CONTACT POINTS.
    I just cut a little slit in my carpet where comptuer is...scratched the paint off the metal there...and screwed the wire down which is attached on the other end to my comp.
    You can also waste 15 bucks at radio shack and get a ground loop thingy that will kinda do the trick. But if you make sure that your ground is hitting metal on metal...you will not need a ground loop isolator.
    I'm a ghost...email me if you have any questions on my old setup
    My way outdated website: http://www.poboytech.net
    FYI: I sold my 96 4Runner and bought a 1985
    Mar 2001
    Cincinnati, OH USA
    Post
    Attach a wire to case then attach it to the chassis. I used a female banana plug and attached a 12 guage wire to the power supply (acrylc box, no metal). That way I could run a wire grounded to my chassis with a male banana plug attached, so I could disconnect it easily.
    Case----female plug[ [male plug-----chassis
    If you are using a PC case attach it to the metal of the case.
    [ 02-03-2002: Message edited by: Maveric ]
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Exclamation
    Moved to Hardware.
  1. I had to wait 16 years, but someone finally made one
    By wizardPC in forum General Hardware Discussion
    Last Post: 11-22-2005, 03:38 PM
  2. Replies: 3
    Last Post: 07-12-2002, 06:42 PM
  3. Resumer Winamp plugin..works with MPC, too
    By Tony S in forum Software & Software Development
    Last Post: 03-30-2002, 05:10 PM
  4. Finally everything works....almost
    By cruzc_99 in forum General Hardware Discussion
    Last Post: 02-04-2002, 09:43 AM
  5. Finally works yay!
    By BootySlap in forum LCD/Display
    Last Post: 05-10-2001, 07:42 PM
