Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: some audio questions for my setup
  1. #11
    Low Bitrate PatrickB's Avatar
    Oct 2004
    Quote Originally Posted by Electrocharge
    Y dont you just run external sound from the laptop straight to the amp with an external card like this one @ ......
    I use it for my setup, granted i have everything totally wired in but it works well. I did use a multichannel amp too..... forget the head-unit
    can u tell me the advantages of using this over a headphone jack to rca out put to the amps? just curious.
  2. #12
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    slightly better quality. but in my experience, external cards provide little improvement over onboard cards to warrant a major splurge. only good advantage to external cards is less interference from the computer since the A/D conversion takes place outside the computer aways from anything that can introduce noise into the mix.
    Your everyday carpc geek and tech guru at your service. *bow*
  3. #13
    Newbie Electrocharge's Avatar
    May 2005
    and if you trying to save space inside ur case an external card would be a good way...
    Friends are just enemies who dont have the guts to kill you!!!
  1. Couple Questions about my setup idea...
    By rshields in forum Newbie
    Last Post: 05-02-2005, 07:10 PM
  2. Power setup questions? Will it work? Know a better way?
    By tom2112 in forum Power Supplies
    Last Post: 04-22-2004, 07:18 AM
  3. Replies: 4
    Last Post: 04-18-2004, 11:50 PM
  4. Epia Onboard audio Vs Creative Audigy?
    By KMPorter in forum General Hardware Discussion
    Last Post: 10-26-2003, 01:57 AM
  5. Special audio preamp circuit
    By claylong in forum General Hardware Discussion
    Last Post: 01-14-2003, 06:19 PM
