Results 1 to 7 of 7
Thread: EPIA M10000 CPU usage by SVCHOST.EXE
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    My Via M10000 works quite well for what I use it for but on occasion it "bogs down" and runs very slowly. That is, it is very sluggish to respond to touchscreen inputs and menu commands etc.
    It usually clears up after a minute or two and its more of an annoyance than anything else. However, today I had the performance monitor in the task manager running to see how much of the CPU I was consuming when doing voice recognition and noticed that the usage would spike at 100% for a period of time, then fall back for a short period, then jump back up. It continued this for a few minutes and then fell back to the 20% range and operated normally without the big spikes.
    During this time, I managed to switch to the processes running and it turns out the "svchost.exe" was the process eating up all of the time. I presume this is some kind of Windows XP thread management process but I really don't know.
    My question is, what is the function of this program and does anyone have any ideas how to lighten it's load on the processor?
    Want to:
    Low Bitrate marshallh's Avatar
    Apr 2005
    Kansas
    Hi,
    The SVCHOST exe is a program built into windows 2000 and XP that acts as a container for the various DLL services (like disk and network management.) The problem doesn't lie in the EXE, but the services that it is hosting.
    You can see some of the servicse your XP machine is running with this:
    Start > Control Panel > Administrative Tools > Services
    Some are mandatory for Windows execution bu some just take of memory (like the Messenger service.)
    Marshall
    Variable Bitrate numbers's Avatar
    May 2005
    The most likely cause for the spikes is malware. As it is working through svchost.exe, I would say a worm would be most suspect.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Crap. You're probably right. I'm normally a Mac guy, my work PC is uber protected but I haven't properly protected the CarPC because I don't often spend a lot of time connected to the net with it. However, it has spent reasonable amounts of time running in the house while connected via WiFi.
    Thanks for the suggestion. I'll bet I find BAD THINGS on it.
    Want to:
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    Try running the microsoft ainti spyware, its free ms.com search adware.
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    Maximum Bitrate Mad Ad's Avatar
    Oct 2004
    Hertfordshire UK
    have you disabled indexing? (AKA stupid resource hog that activates when it feels like it)
    right click+properties on all yoru drives in my computer and untick allow indexing service blah blah, ignore anything it cant manage. Also you can disable it in services, start+run+type services.msc and choose disable in the dropdown for the indexing service.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    No, I haven't. Good suggestion. I'll do that.
    I'll be running the malware software on tomorrow morning's work run. I'll let you know what I find out.
    Want to:
  1. High cpu usage when audio is muted.
    By Arathranar in forum RR Bug Tracker
    Last Post: 03-23-2005, 04:51 PM
  2. 100% cpu usage with WMP10.0
    By ZenerDiode in forum Software & Software Development
    Last Post: 03-01-2005, 01:28 PM
  3. Hi CPU usage on certain MP3s.
    By ZenerDiode in forum FrodoPlayer
    Last Post: 02-27-2005, 03:13 PM
  4. FS: EPIA M10000 Mobo & 512Mb PC133 SDRAM (Brand-New).
    By buildfromscratc in forum Classified Archive
    Last Post: 09-20-2004, 09:32 AM
  5. Replies: 0
    Last Post: 05-21-2004, 08:12 PM
