Results 1 to 4 of 4
Thread: Heatsink loose on MII12000
    Oct 2004
    Glasgow, UK
    I was about to mount all components in my case when i noticed that the heatsink under the fan on my MII12000 is kinda loose. It is held down with 2 small springs. Is this normal, or should it be tight on the board? Should i lift it off and use some thermal paste?
    Low Bitrate madmartigan's Avatar
    May 2005
    Canada
    Thermal paste is always good. Never build a PC without it.
    Maximum Bitrate Mad Ad's Avatar
    Oct 2004
    Hertfordshire UK
    spring mounts, yes, normal - not ideal but normal yes- do a trick with a couple of thin washers if you want to tighten it up
    it should have some paste - probably just a thin layer of cheap white silicon if its like my M10000..... if you want to do the business then scrape it off and use some arctic silver instead, much better stuff, its worth at least a couple of degrees C @ 50 over the white
    Oct 2004
    Glasgow, UK
    Thanks for the replies. Think illl just use some paste on it.
  1. P3 fanless heatsink suggestions?
    By CombatCQB in forum General Hardware Discussion
    Last Post: 07-25-2004, 06:13 AM
  2. Best low profile P4 (socket 478) heatsink?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 05-22-2004, 09:05 PM
  3. Opus 90w, heat problem and the heatsink
    By samc in forum Power Supplies
    Last Post: 04-19-2004, 09:07 AM
  4. sproggy heatsink
    By GRUNT in forum Power Supplies
    Last Post: 10-05-2002, 06:15 PM
  5. Replies: 15
    Last Post: 04-26-2002, 11:16 AM
