Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Supersize my Palm
  1. #11
    Jan 2006
    The trouble with the presenter-to-go is that it will only OUTPUT to an external LCD touch screen. It makes no provision for feeding touches of the external touchscreen back to the PDA.
    For presentations this is fine, but it's no good for an in-car install - you would be able to see the screen output from your PDA but you would not be able to interact with it without touching the screen on the PDA itself.
  2. #12
    Nov 2004
    Atlanta
    Given Up
    Yep, I think that pretty much defeats the purpose of the PDA install. I have given up on the palm install for now. I just do not see the hardware or software support. Some of the Pocket PC PPC stuff is pretty promising. You can now get some of the older PPCs used for as little as you could a palm. This Thread is pretty interesting.
    Pocket PC-based carputer idea.
    The fast startup time and no need for shutdown controler is the big advantage. Also, I think the overall cost would be cheaper.
    Hotoru
  3. #13
    Maximum Bitrate Don 944 LA's Avatar
    May 2004
    San Diego / Los Angeles
    Sorry, but by the time you dump massive amounts of $$ into that thing ... get a PPC
    and then run Linux on it....
    You will be much happier
    Don
    ( this was NOT a slam post ) only an enlightenment.
  4. #14
    Nov 2004
    Atlanta
    Whats Bad?
    I am not sure I understand your reply. When you say "that thing" you mean a car computer with windows 98 lite, the PPC project I linked to above, or the palm project with which I started this post?
    Hotoru
    Quote Originally Posted by Don 944 LA
    Don
  1. Palm Pilot Remote Control Question
    By xanimal in forum Software & Software Development
    Last Post: 08-29-2003, 11:38 AM
  2. Using a palm os device as controller
    By babas151 in forum General Hardware Discussion
    Last Post: 05-17-2002, 07:59 AM
  3. Palm Battery drain fix
    By Loftus in forum General Hardware Discussion
    Last Post: 05-01-2002, 08:57 AM
  4. Palm controlling INFO
    By Loftus in forum Software & Software Development
    Last Post: 02-27-2002, 04:53 PM
  5. Dell P4 1.5Ghz + Palm M100 for $599
    By Falcon62Travis in forum Off Topic
    Last Post: 09-27-2001, 11:20 AM
