Results 1 to 9 of 9
Thread: UnHappy taxi driver
    Low Bitrate Mush's Avatar
    Dec 2004
    UK
    UnHappy taxi driver
    hi
    can anyont tell me how to go about reducing/elimination interference for the car pc.
    My full- time ocupation is being a taxi driver and ever since ive installed the CAR pc my CB signal has droped to less than half the strenghth, but when i close the pc its gose back to normall. It only affects The cb radio and not the car fm/am Radio.
    Any sugestions??
    Lilitput 7" touch screen :-( , Epia -M 256ddr, Opus150w,
    Banned
    May 2005
    Ground Loop issue
    Bugabyte has taken the time to write a nice FAQ -Frequently asked Questions that addresses this issue as well as others that have to do with interference
    Its in the FAQ Emporium section.
    Or just search the forums and use the keywords - ground loop
    Here is a link as well to his post FAQ: Getting Rid of that Whine or Buzzing Noise in Your Speakers
    Quote Originally Posted by Mush
    hi
    Any sugestions??
    Constant Bitrate bulgogi777's Avatar
    Jun 2004
    NW FL
    Actually, this wouldn't be a ground loop issue. That has to do with noise in the audio line, this is a wireless interference problem... probably much like how many of us have trouble with our key fobs working when the carputer is on. Here's a couple threads on the issue, but no real solution
    mysterious door locks...
    Carputer interfering with keyless entry
    90% done - Sempron 64 2600+, MSI RS480M, 512mb, 80gb hd, 7" Lilliput, 802.11g pci, Itrek gps, Panasonic slim slot DVD/CDRW (broke :( ), Hauppage Wintv, Iguidance 2.0, Opus 150w, Griffin Powermate, Optima Yellowtop, Infiniti 6002i & 9603i
    My Install
    Dec 2004
    UK
    THANKS for information. i think ill try to ground the case as well as sheild it inside another case just to see if that dose the trick
    Jun 2004
    NW FL
    let us know how that works out for ya
    My Install
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    There's nothing worse...
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    You need to add additional shielding on the the computer and also all wires going to and from.
    You can buy EMI shielding from Mouser or digikey (i think) that has adhesive on one side. THis should help. Also install ferrets on both ends of all of the wires to cancel out EMI
    Good luck Let us know how it goes
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    I had a horrible issue with EMI. It completely eradicated all FM radio signal and it rendered my alarm keyfob useless. I ran the computer in the trunk with a fiberglass and wood case.
    The solution was to house the computer in a small metal (aluminum) case and bury it underneath the trunk carpet so the case sat flat against the body of the car.
    After this my problems were solved
    I also had FM reception issues with the GPS reciever sitting on the rear shelf. I since replaced it with an OEM based reciever with an external antenna (still on the rear shelf) and that problem has now also been solved
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    !!!!!Wow! You know, I just thought my keyfob was sucking! It seems like the range varies everytime I get out of the car. I'll bet it's the EMI.
    Want to:
  1. XM Driver Install Problem
    By MikeH in forum MacCar
    Last Post: 04-24-2005, 12:22 PM
  2. cypress serial driver?
    By xtra in forum GPS
    Last Post: 04-23-2005, 06:20 PM
  3. XP default video card driver pickle
    By deetap in forum WinNT Based
    Last Post: 04-12-2005, 12:00 PM
  4. Replies: 4
    Last Post: 01-01-2005, 05:19 PM
  5. USB Sound Card with ASIO driver and volume control
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 02-04-2003, 12:00 AM
