Page 1 of 7 1234567 LastLast
Results 1 to 10 of 70
Thread: Pioneer IP bus hack confusion
    Oct 1999
    London England
    Question Pioneer IP bus hack confusion
    I am about to do the aux in hack for my pioneer DEHP4300R. I have found the diagrams from searching but there are 2 different schematics. On one diagram the pin on the middle row is used for the common ground/left channel -. But on the other it is used for left channel +. Which diagram is correct since I read that some people were having problems with distortion and the input being too quiet.
    Diagram 1
    Diagram 2
    Cheers
    FLAC Mastero's Avatar
    Aug 2001
    India
    Post
    hey buddy i dont about your second diagram but surely i have used the first one in my car 8650 pioneer and it works great ,,,
    mastero
    Oct 1999
    London England
    Post
    cheers
    moahdib's Avatar
    Jul 2000
    Post
    First diagram is an error...go with the second one bc it's straight out of a pioneer cd-rb20 schematic. I have used it myself and it works too.
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
    Jun 2001
    netherlands
    Post
    dont know about the first (havent tried it) but the second worked for me
    time for the sig:
    '00 VW golf TDI upped to 130 HP - 18" RS 6 wheels - liliput 7" tft in indash housing - epia 10K - SB audigy - caliber 1 fahrad CAP - RF punch amp - hollywood 1.6K mono amp - boston acoustics pro - RF 10" DVD sub
    Aug 2000
    Pgh, PA
    -+[MP3PC]+-
    Apr 2001
    Here, There, Everywhere
    To help clear this up (and since I couldnt find a definate answer anywhere on this forum).....
    I installed a Pioneer Head Unit with my old JL-Audio speakers into a mates car on the weekend ready for a mp3car system too and was looking around for all info here.... this was my result -
    • Both diagrams listed above work. BUT (and a big but) the SECOND diagram results in a much quiter output sound, so I used the FIRST diagram (Arby's one). Im guessing that this is deliberate for different versions of Pioneer CD-changers?
    • The AUX mode does not enable automatically, which cause me alot of trouble. I assumed that with the headunit detecting a ground on the two return audio pins that a new option would appear. After alot of scratching heads and another search I found a post from Maestro saying that you need to hold the FUNCTION key for 4-seconds with the power off to bring up a hidden menu and enable AUX mode. We didnt have a FUNCTION key on our headunit but played around with the main keys and found that the button that changes the FADER/EQ/BASS/TREBLE/ETC was the equilivent of the function key - and worked a treat....
    • Ensure you ground the ground wires back to the chassis of the head unit to get a good quality signal. I soldered directly to the IP-BUS pins on the back (I have a thin soldering tip, steady hand and a few hundred hours PSX MOD chip experence - so I am used to fiddly soldering work!) and used heatskrink tubing over each wire once soldered to avoid the chance of shorting - due to close distances between the IP-BUS pins...
      hope that helps clear things up once and for all...
    Project - GAME OVER :(
    jol
    jol is offline
    FLAC jol's Avatar
    Jan 2002
    Mellansel, Sweden
    Aux-mode enabling is in the manual.
    A guy in sweden sells theese, they're $37.5 each...
    I coulnd't find any reseller of the original one, so i got one.
    they were 3 internal cdrom audio connectors on top of each other glued together, with the center hole drilled up to fit, and shrinktubing around it. When I got it, I couldn't believe it was so easy/cheap made, but it works, and thats enuff for me
    Apr 2002
    North Yorkshire, UK
    <sigh>
    The things I wish I'd thought of....
    When I first tried it out, I found it was very quiet, but that's partly what the rest of the crap in the CD-RB20 circuit is for.
    Dave
    Maximum Bitrate CrazyLittle's Avatar
    Jan 2002
    Oakland, CA
    Crutchfield has one for $29 that's a 3rd party IP-Bus cable, professionally made. Works great, less filling. Also less likely to come loose or screw anything up because they use a REAL IP-bus plug. search for Cruthfield number: 469PiOPRCA
