Results 1 to 10 of 13
Thread: Making a internal drive external
    Dec 2001
    Houston Tx
    Question Making a internal drive external
    Okay, I am very new at computers, I love them, but am not hip on the lingo yet. I am going to attempt to install a DVD-Rom drive (Pioneer slot load to be exact) somewhere close to my dash while the casing of the cpu is in the trunk. My question was if I am going to run into any problems doing this. One of the problems that come to mind is that I will be losing a bit of voltage and or signal since it has to travel a long distance (about 10-12feet). One other question, have ya'll had luck with the Pioneers? I am mainly concerned about it skipping whenever I hit bumps. Any and all info is greatly appreciated. Thanks in advance.
    I have a 2001 Prelude. bone stock (gimme a break, it is brand new)
    I am looking to start the install very soon.
    Mar 2001
    Cincinnati, OH USA
    Post
    Your best bet would be to get an Internal to external case. They convert the IDE signal to USB or Firewire. Since it is a DVD drive I am not sure how Firewire would hold up, 24 MB/sec should be good enough but may not be. Here is an idea of what to look for. External case
    http://www.mp3car.com/usersites/Maveric/ M.A.V.I.C. System
    Asus MB, PII 266, 192 MB Ram, 6.8" LCD, 6 Disk CD-ROM, 21 Gig HD, All-in-Wonder Video w/ TV Tuner, Irman, Windows ME, Winamp, Cobra III -- All in a custom acrylic case.
    http://www.mp3car.com/usersites/listings/ MP3car Listings - Please add to it! :)
    Aug 2000
    Abbotsford, BC, Canada
    Post
    Hey... Love your nickname, "Jenny"
    ~m
    [ 12-06-2001: Message edited by: dos4who? ]
    PII 266, 512 MB RAM, 10 Gig, 36x CD-ROM, 16x DVD, DeLorme GPS, 5.6" LCD Screen, Dschmidt power controller, Keypower ATX DC-DC Supply, PowerAmp Macro controller, Dauphin mini-Kbd.
    Sony Head Unit, Sony Unilink input selector, rear deck Kenwood 6x9's, stock door spkrs... All in my '96 Civic, of course :}
    BC ROCKS!!!
    Nov 2001
    Colorado
    Post
    Well, the player Obscured in my signature has an external IDE interface I made with a Centronix SCSI cable. It works well, even though I'm stretching the limits of IDE cable length.
    You're not going to make it 10-12 feet with IDE. USB should do fine, as it has a longer cable limit then even firewire. It should have the bandwidth you need, too. Firewire can definitely handle the bandwidth, but I believe you may be pushing the cable length limit, and the cable itself may hit you hard in the wallet.
    SnackPack
    First Player: Obscured
    Second Try: No Web Page Yet, using MSI-6215
    Sep 2001
    Atlanta, GA
    Post
    FYI, Firewire limit is 15 feet, unless you have repeaters - in which case you can go up to 236.
    Jonathan
    JZ CarPC - 1998 Volvo C70
    Shuttle SV-24 Celery 400Mhz 128MB SDRAM 60GB HD DVD, 12.1" VGA TFT LCD, Sproggy/Mastero DC-DC ATX PSU, Mucha ATX shutdown controller, Co-Pilot GPS
    Jul 2001
    Post
    Or you could try and find yourself a SCSI DVD drive, and then you would have no problems with distance..
    Mar 2001
    Cincinnati, OH USA
    Post
    I don't belive USB can do DVD SnackPack. At less than 1MB a second there won't be enough bandwith. USB 2.0 may be able to handle it though.
    Dec 2001
    Houston Tx
    Post
    thanks everyone...
    Skinnyboy, your idea sounds the most appealing to me so far, but I was wondering if I need whats called a SCSI expander, or can it run that many feet by itself? also, can you get a SCSI connection on one of the ports on the back of the computer, or do you have to run the ribbon of wires from the inside of the housing? thanks a bunch.
    Nov 2001
    Colorado
    Post
    You can get a SCSI card which has an external port. However, SCSI cables are also very expensive. You may be paying at least 75 bucks for 10-12 of cable. It's thick cable, too. Not very ideal for hiding away in a car.
    SnackPack
    SnackPack
    Mar 2001
    Cincinnati, Ohio
    Post
    Thats why you extend it yourself with some Cat-5 STP
    Clarion 200watt head unit w/ Aux in.
    Kicker 800watt 4 channel amp
    In a 96 Grand Prix SE.
