Results 1 to 10 of 17
Thread: Need some help with a WRX Installation.
    Mar 2005
    Arrow Need some help with a WRX Installation.
    I've been lurking on these forums for a pretty good amount of time, and I've finally collected most of the parts I need to really kick this project off.
    I'm using a Mac Mini as my carputer, and I have a 7" Lilliput LCD screen.
    It would seem that buying a bezel from TMZ is the way to go for mounting the screen behind the existing radio bezel, but here's where I need help.
    I'm not sure how to get sound from the mac-mini to the speakers. I will no longer have a head unit because I'll be using the computer, so I'll only have the harness in the double-din space. It seems like I need a 4 channel amplifier to power the door speakers, but I don't understand what to do next. The Mac Mini only offers 1/8" phono out...how will this work with 4 channel audio in my car? What kind of amp should I buy, any recommendations? I'd like to keep the stock speakers, I think they sound fine and I'm not really concerned with upgrading them right now.
    So as I mull this over, I arrive at the #1 question. How do I get wires from my harness to the amplifier which will be mounted either in place of the non-functioning stock sub under the passenger seat, or in the trunk. *sigh* Tough.
    Thanks to anyone who can help.
    Constant Bitrate dan__wright's Avatar
    Apr 2005
    UK
    you can get a cable thats 1/8" jack to phono, one end in the mac, other in the amp, get a wiring harnes adator to use factory wiring and your done.
    also, in the FAQ there is thread that shows you just this.
    Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
    PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
    Toys:K8055 relay board, Elmscan OBDII
    Type-R Mini
    Mar 2005
    Quote Originally Posted by dan__wright
    I'm still not really clear. I understand using 1/8" phono to RCAs to go to the amp, but if the amp is going to be located somewhere other than behind the screen (which it obviously can not possibly go) how do I get the wires that terminate at the harness into the amp?
    |macmini|------(phono-to-rca)-------|AMPLIFIER|------harness inside the dash?
    The wires are terminating at the speakers in the doors or at the harness clip inside the dash. How do I get the amplifier into the mix?
    Jun 2005
    hey nolan
    i'm doing the planning on my wrx also. so i will share the wealth of info i've found
    http://www.geocities.com/svxdc/WRX-pinout.htm
    is the pinout schematics. i will prob buy a reverse cable thingy liket that, i just run the currect wires to the amp. that way, everything is still reversable.
    i'm not going the mac mini route like you, mostly b/c of frodo player. but feel free to exchange info back and forth since we are in the same boat, or car... or ... you konw what i mean!
    update:
    HOW TO: Get sound from PC to Car Stereo / Amp
    all the info you need for what you asked for!
    Newbie White 350z's Avatar
    Jun 2005
    Arkansas
    Quote Originally Posted by NolanSmith
    Your amp will have a harness that has bare wires for front l/r and rear l/r. You connect those to the harness that was in the back of the stock radio (because that harness also had front and rear l/r). The easiest way to do this is to buy a wiring harness adapter that would allow you to plug an aftermarket head unit into the stock wiring. Plug one end into the harness where the stock radio was. The other end will have bare wires, solder those to the harness that comes with the amp. You can extend the cables as long as needed since you are soldering 2 adapters together. I've got a picture below in case that was confusing.
    CarPC Status
    [|---------] 10% Complete
    Home Rig -
    Athlon 64 (939) 3200+ (Watercooled)
    DFI NF4 SLI-D Mobo
    Gigabyte 6600 128MB PCI-E Video Card
    (4) 9GB U160 SCSI HDDs in 36GB Raid 0 Array
    160GB Seagate S-ATA Drive w/NCQ
    Dell 20.1" Widescreen LCD
    Mar 2005
    Okay. Will this give me 2 channel or 4 channel audio? I'd like to have 4 independant channels, but it would seem like the splitter would only give me two at most. Also...since it's being split, will the volume be affected?
    Variable Bitrate numbers's Avatar
    May 2005
    The example in the picture is for two channel, but the amp is capable of four channel. To get four channel you need a four channel amp and a sound card in the computer that supports four channels. Many support only two, which is how the example is.
    Jun 2005
    Arkansas
    Splitting the signal does degrade it, yes. And it will only be 2 channel sound - the rear will have the same as the front. I don't know too much about macs... can you buy an external (USB or firewire) sound card?
    CarPC Status
    Home Rig -
    DFI NF4 SLI-D Mobo
    Mar 2005
    Definitely can, and I plan to. That should solve the problem. I created an awesome diagram, but I don't have anywhere to host it. Oh well.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Another 2 options you may consider to have 4 independent without buying 4 chanels amp.
    Push the Stock HU DEEP inside the dash so that the LCd and sit in front of the HU. Relocate the front panel to somewhere you can control. That is only if the stock HU's front panel can be separate like a detachable face plate. My GM AC/Delco make HU can do that, but my Matrix doesn't have enought room to push the HU deeper. That is why I opt to buy a new HU and relocate other thing around.
    Another option is buy a cheap/capable after market HU with AUX in and install in in the glove box. Relocate the face place if you want.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  1. Why Impreza WRX?
    By cproaudio in forum Off Topic
    Last Post: 09-29-2005, 03:48 PM
  2. Replies: 9
    Last Post: 03-31-2005, 03:40 AM
  3. :( So frustrated with my WRX car computer!
    By rabydanimal in forum General Hardware Discussion
    Last Post: 11-10-2004, 10:27 PM
  4. Writeup Lilliput installation in TM-701L housing
    By spyhunter in forum LCD/Display
    Last Post: 05-17-2004, 07:58 PM
  5. Car Stereo Installation Video's for Sale
    By johnram in forum Classified Archive
    Last Post: 09-05-2002, 11:27 PM
