sounds like your opus is maxed out. mine did the same once i tried to power the usb from my opus 150. once i disconnected the usb hub, the pc fired up again.
so, i purchased this a while back and had issues since the drive is up in front and the carputer is in the trunk. I have the external enclosure where the power comes through the PS2 cable. I noticed that the drive didnt work well because of power issues being that the cables needed to be too long.
So, i did some searching and found that i could power the drive using the molex connection. I did exactly this. Ran a power and ground from the (red) and (black) from the molex.
After wiring everything up and using 12 gauge wires, my opus 150w wouldn't power up. The green light wouldnt blink as usual. As soon as i pull the tapped power wire from the molex the opus starts up.
Am i using the full wattage of the opus?
If so, what other options if any do i have in powering my dvd drive.
thanks guys
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
thanks for the response. Now i need a new way to power this darn thing.
Any ideas???
bump
so, is there any other way of powering my dvd drive not using the opus?
Could use another power supply. So you have two. Have one control PC, one for periphials
You could get this should work for you
http://cgi.ebay.com/ws/eBayISAPI.dll...784150033&rd=1
That should work. It says it is capable of 1000ma (Thats 1 amp, by the way). You may need toOriginally Posted by lagunatl2k
to determine what the operating amperage of your Drive is, but that should be enough.
Michael
so would i need to use the cig lighter or can i just wire it?
Thanks for the link Laguna.
