Results 1 to 9 of 9
Thread: Hibernation and Lilliput Weird Issue
    Apr 2005
    Trust me I SEARCHED...but couldn't find the right answer. I have a laptop and my Lill 7" will flash on after a resume from either a hibernate or and stand by. Thats it for 1 second. It works fine on a normal boot. It's almost like the laptop changes its mind and try's to send video only to its own screen. I have the newest drivers of everything available. The laptop is an older HP P3 with a savage 8mb vid card. I just want to boot from hibernation or stand-by so I don't have to wait. Do I need to disable something? I don't know. Any Ideas? Thanks
    mox
    mox is offline
    Constant Bitrate mox's Avatar
    Nov 2004
    The Netherlands
    My guess would be the lilli being unable to actually report its presence to your laptop when resuming. The lilli's VGA connector is somewhat crippled -- it only uses RGB and 2 syncs. Have you already tried resuming with a "normal" monitor hooked up?
    CarPC status: HW all done, SW needs tweaked.
    Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
    Software: RR, MM/FD
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    That is what I am suggesting too. Before blaming the poor Litleput , try it on a different monitor. It could be that the laptop/video card that has "blinking" problem.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    mox
    mox is offline
    Nov 2004
    The Netherlands
    Question remains how to fool the laptop into believing that a "normal" monitor is attached. I don't think this can be done easily, cause the monitor is providing serial data via its ID-pins regarding brand, type, refresh rate, resolution etc.
    Software: RR, MM/FD
    Apr 2005
    No I haven't tried a normal moniter but I will. I didn't know that about the lilli. Humm, if you guys think of a solution, let me know.
    Apr 2005
    Hey, I got it to come out with no problems on another moniter. What is the deal with the lilli? It can't see it because it has less pins in the cable for signal or something? Is there a way to fix it? I would LOVE to be able to use stand-by! Thanks
    Jun 2005
    chicago, Illinois
    Some laptops give you the ability to toggle the monitors through shortcut keys. If memory serves me correct the [fcn] button on the bottom left of the keyboardand one of the "f-keys" on the top of the keyboard with an icon of a monitor looking thing.
    PROGRESS:
    Apr 2005
    Does anyone else have this issue? I still can't figure it out.
    Jan 2005
    hibernation
    I have the same issue.. if I disconect the lillu the hibernation works fine ... if i conected doesn't start... just hangs..
    have you been able to find a solution???
  1. Replies: 3
    Last Post: 05-11-2005, 02:00 PM
  2. computer freezes at hibernation startup
    By bobthebaker in forum General Hardware Discussion
    Last Post: 01-12-2005, 09:38 PM
  3. Ibm laptop using external lilliput
    By Spec-pc in forum LCD/Display
    Last Post: 12-06-2004, 01:41 AM
  4. gamma problem after hibernation
    By djkriz in forum LCD/Display
    Last Post: 09-22-2004, 11:19 AM
  5. Lilliput to Opus & time settings
    By nibix in forum Power Supplies
    Last Post: 06-29-2004, 11:44 PM
