Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 55
Thread: I will BUILD IT I MEAN IT THIS TIME
  1. #41
    Feb 2005
    UK, High Wycombe
    create a bootable floppy disk, set you bios to boot from the floppy drive.
    When it loads up type:
    fdisk /mbr
    and type y (yes) for any confirmations.
    This will write a new master boot record, restart the computer and set the bios to boot from th hard drive.
    If that doen't work run scandisk from DOS and see if that works.
  2. #42
    Dec 2003
    Houston TX
    Quote Originally Posted by affie
    fdisk /mbr
    I have no drive (i.e floppy cdrom or anything else), but thanks anyways. If its not a hardware problem i'll just take it to the local computer shop it shouldnt be more then $50 to repair it.
    *Laptop $107
    *Hauppauge WinTv-USB FM $36.02
    *USB Drive Enclosure $24.95
    *USB 2.0 PCMCIA Card $19.85
    *Crossover Cable $25.97
    *Earthmate GPS LT-20 $97.60
    *2.5 adapter 16.24
    Total - $327.63
    Current Budget - $322.37
    Aug 25. Deadline
  3. #43
    Dec 2003
    Houston TX
    I asked a local computer guy my problem he told me it could be the boot and said it you be around $80.Well I was balacing my budget on this build and that wont work. So can someone please help me with this. I dont know how to do fdisk. Maybe I can manualy input what i want booted, but i dont know how to do that either someone please help me.
    *Laptop $107
    *2.5 adapter 16.24
    Total - $327.63
    Aug 25. Deadline
  4. #44
    Zerach's Avatar
    Jul 2005
    Talking LCD touchscreen
    I would like to see you get a 10.4" for the money you have, but I don't think it's possible they're tons o $!
    But hey shop ebay and you might!
    http://cgi.ebay.ca/ws/eBayISAPI.dll?...sPageName=WDVW
    The above seems like a good deal and there's less than a day! check it out!
    http://cgi.ebay.ca/ws/eBayISAPI.dll?...sPageName=WDVW <- this ones cheap but no power supply so it's not workable unless you get one.
    As for your HD problem what size is it? It sounds like what used to happen with older OS's and large HD's. If your using Windows NT or 2000 they only were able to use a 10GB NTFS partition, if you used a 20GB it would be fine, until you got disk space used over 20GB and replaced already existing system files. What happens is the system files get re-written and the tail of the free disk space and the system files could no longer be read by the OS at boot up.
    It might not exactly be your problem but the install of mediaplayer and no boot is what makes me think it was. Typically we got this issue after a service pack install on someone using more than 10GB of free drive space.
    I think someone mentioned it earlier, use XP and you shouldn't have these issues.
    About your RAM if you're looking at doing video, get a decoder board. I think you already have which will help in vids and mp3 for that matter.
    The 256 limitation on RAM may be an issue, but I can help you tweak XP to make it run on bare bones, I had a 400Mhz PC running XP and only using 64MB on idle of memory.
    Cheers
  5. #45
    Dec 2003
    Houston TX
    Quote Originally Posted by Zerach
    Cheers
    Thanks for the diagnosis but how would I be able to fix it?. Also i'm using a 20GB hard drive. I have a desktop that has the same processing speed and Ram (and hard drive size) i'm running xp on it with no problems.
    LMP
    *Laptop $107
    *2.5 adapter 16.24
    Total - $327.63
    Aug 25. Deadline
  6. #46
    Newbie chepnut's Avatar
    Jul 2005
    Well without a cd or floppy to boot from, you are going to be farked! You can get a external cdrom from ebay
    http://cgi.ebay.com/ws/eBayISAPI.dll...Name=WDVW&rd=1
    for 32 bucks shipped, after you get the drive you would go into the bios and have the laptop boot from the cd, from there just install windows XP. XP will reformat the drive and then fix the MBR. The 32 dollars is way cheaper than paying 80 for a shop to basicly do the same thing, and you wont have a cd drive for future use.
    You can also take the hard drive out of the laptop and get a adaptor
    http://cgi.ebay.com/ws/eBayISAPI.dll...ory=41994&rd=1
    make that the primary drive on your desktop, and then install xp and put it back into your laptop after its done. I know that this solution is super ghetto, but I have had to do it before. Windows may freakout when it boots up and detects all the new stuff from your laptop like the motherboard and stuff like that but most of the time windows will just install the drivers needed and go on its way.
    The 3rd option is put the drive in your desktop as the main drive, boot from the floppy or cd and at the comand prompt type
    fdisk /mbr
    as posted earlier by affie
  7. #47
    Variable Bitrate spud42's Avatar
    Oct 1999
    brisbane,qld,australia
    DMN
    what model is the laptop ? i work for compaq(now HP)
    most of these laptops will use a floppy via a cable to the parallel port. should be able to get one cheap on ebay or borroy one from a friend or workmate...
    how many memory slots do you have and how many free?? i have 2 64 meg pc100 memory sticks i cant use......
    Volvo V40 Phase 2 2002. T4 turbo upgrade.... currently no mp3 or carputer..... researching options
  8. #48
    Dec 2003
    Houston TX
    Quote Originally Posted by spud42
    DMN
    Compaq Pressario 800. I will try what chepnut said. Dam I SHOULD HAVE INSTALLED XP WHEN I HAD THE CHANCE, BUT I WAS TO LAZY
    *Laptop $107
    *2.5 adapter 16.24
    Total - $327.63
    Aug 25. Deadline
  9. #49
    Mar 2005
    how do you plan on boot up the machine?
  10. #50
    Dec 2003
    Houston TX
    Quote Originally Posted by chepnut
    fdisk /mbr
    Well I got a adapter for the harddrive i'm going to try to take the hard drive out and use my 5.25 eclosure to connect the computer to my desktop Laptop. This is going to be a very time comsuming project so i will start it this weekend. I just noticed that i have everything I need except a way to connect it to my car and a Touch Screen.
    *Laptop $107
    *2.5 adapter 16.24
    Total - $327.63
    Aug 25. Deadline
  1. Beta: CCarProject
    By BenjaminS in forum MacCar
    Last Post: 09-27-2006, 01:25 AM
  2. boot up time and shutdown time. What's your tweak?
    By wei2cool in forum Software & Software Development
    Last Post: 05-21-2005, 10:28 PM
  3. Capacitor time formulas (for noobs)
    By KyleYankan in forum Newbie
    Last Post: 03-30-2005, 04:32 PM
  4. Optimize Load time of CF?
    By HostileJava in forum Centrafuse
    Last Post: 03-16-2005, 08:40 AM
  5. EPIA VIA M10000 Mini ITX in a 6x9 Speaker Box pic. 2 hour build time.
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 02-13-2004, 01:24 PM
